Focus Central Locking issue
Old Feb 3, 2010 | 08:27 PM
ukste1349's Avatar
ukste1349
Default Focus Central Locking issue
My central locking does`nt seem to open my front passenger door.
When I use the fob I must open the front pass door with the door handle lock inside the car.
When I want to lock the doors they dont all lock or less I have locked the front passanger lock from inside first.
when it is locked from the inside I can lock the car using the key fob and the lights will flash.
Anything I shoud be checking infuse box area?
Thanks
Old Feb 3, 2010 | 08:34 PM
martysmartie's Avatar
martysmartie
Think this is common problem certainly on Mondys and Fezzas, have you tried lubricating the lock, otherwise maybe ECU fault.
Martin
Old Feb 11, 2010 | 06:16 AM
melinamotor's Avatar
melinamotor
Farpylee
I run two foci, a 1.8 and a 170. Try disconnecting the battery for 20 mins and reconnecting. The locking mech on the focus suffers badly in the cold weather if it has not been checked regularly. A higher the mileage and age also lead to locking faults if they have never been looked at.I had a similar problem on the ST200, the cold weather knocked out the rear passenger door mechanism, worked fine when the weather warmed up.
It might not work but worth a try.
Old Feb 11, 2010 | 06:20 AM
Chris69's Avatar
Chris69
my central locking unit/motor in the passenger door went on my focus and it did exactly as you've described.
would only lock/unlock manually but not when used with the central locking.
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
gingeRS
Sep 4, 2015 06:29 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
Sep 3, 2015 10:49 AM
