oil pressure problem (CVH)
Old Jan 6, 2005 | 10:27 AM
CabrioTurbo's Avatar
CabrioTurbo
Default oil pressure problem (CVH)
Rite guys i think ive got a bit of a problem with the oil pressure on my cab Its currently got a fairly new (under 3k mile) 'high pressure' oil pump from PJ motorsport.
When i start the car in the morning and let it idle i get arround 60Psi of oil pressure... (ie 60Psi @ cold idle)
now when ive been driving a while and the oil is getting up to temp say anywhere between 70-90 degrees then i get really shit pressure at idle.. ive seen it as low as 15 Psi! although its normally arround 25Psi which i still think is very low...
When motorway cruising or accelerating i see arround 40Plus psi of pressure....
ITs just at idle is crap...
Whats causing this... i know the oil will be 'thiunner' when warm and hence there will be less pressure... but it drops so dramatically!
Ive tried changing the oil and it does seem to improve the pressure but only by arround 5 Psi and then after 500 miles or so it will drop again
Any help much appreciated
CheeRS
Phil
Old Jan 6, 2005 | 10:30 AM
Matt's Avatar
Matt
Default Re: oil pressure problem (CVH)
quite acceptable for a cvh at warm idle imo
Paddy's Avatar
Paddy
Legend
hello mate, you got an oil breather kit fitted?
Old Jan 6, 2005 | 10:32 AM
CabrioTurbo
DIY oil breather patented Harpic lime descaler bottle
I guess 25Psi just 'looks' low on my gauge then as it goes up to 120Psi or something!
Old Jan 6, 2005 | 10:35 AM
CabrioTurbo
oh by the way im using 10-50 Mineral oil
Old Jan 6, 2005 | 10:37 AM
Paddy's Avatar
Paddy
Legend
quality that even beats my injector rail fashioned out of a banana and 4 straws
Old Jan 6, 2005 | 10:39 AM
CabrioTurbo
had to use my engineering degree to get the fucker to fit rite as well!
The nice 'swans neck' on the end of the bottle allowed an easy fit to the bteather hose that goes to the block though!
Rick's Avatar
Rick
15 psi on idle when hot is fine You wont get more than 40 when hot due to the pressure releif spring in the pump
Old Jan 6, 2005 | 10:41 AM
CabrioTurbo
Really! so ive been worring about nothing then... when it idles that low when warm i keep my foot on the gas a bit to bring it back up to 20 Plus psi.. im just worried that im gonna fuck the engine driving will 15psi of pressure
Old Jan 6, 2005 | 10:47 AM
Ryan's Avatar
Ryan
a high pressure pump is what fooked my engine mate.
which i had used a standard ford item in the end "uprated" doesnt always mean better
Old Jan 6, 2005 | 10:50 AM
CabrioTurbo
i remember you saying that a burtons pump buggered your engione.. which TBH is partially whats made me worry about this issue!
Its your fault im so apranoid!
what exactly happened in the end that fucked your engine up!
Old Jan 6, 2005 | 10:54 AM
Ryan's Avatar
Ryan
low oil pressure when warm basically.
after a while i.e like 2-3k miles i noticed the oil pressure light occasional flicker after a thrash on the motorway when pulling on to stand still, made me wonder, asked on here, spoke to Karl, really helpful, straight to the point
he said what pump you running, i said burtons high pressure, he said, thats the engine fucked then
whipped the sump and mains off and sure enough he was right
I never fitted an oil pressure gauge, wish i had now, wish i had done alot of things differently, but you live and learn, its all part of the expensive ford "experience"
You can never have to many "make you really paraniod" guages
Old Jan 6, 2005 | 10:57 AM
CabrioTurbo
the oil light used to flicker on my old cab... 2 days later a con rod and big end decided they would no longer like to be attached to the crank and proptly exited stage right!
Old Jan 6, 2005 | 11:01 AM
Ryan's Avatar
Ryan
Old Jan 6, 2005 | 11:20 AM
WutangRS's Avatar
WutangRS
yep ive had problems with my burton pump. changed for a standard one but im pretty sure the bearing will have been worn. use to make nearly 100psi on start up and about 50psi when running and about 20 on idle.
it dont do that know though
Old Jan 6, 2005 | 11:27 AM
Oranoco's Avatar
Oranoco
I'm sure I read somewhere that the CVH doesn't take too kindly to high pressure oil pumps and that a high flow pump was preferable.
Old Jan 6, 2005 | 11:31 AM
Spax's Avatar
Spax
Mine runs at up to 78psi from cold and drops to 25psi when warm
Old Jan 6, 2005 | 03:29 PM
Wazzzer's Avatar
Wazzzer
My oil light is flickering now and then, sounds like my pump is on its way out then...
Old Jan 6, 2005 | 03:34 PM
Paddy's Avatar
Paddy
Legend
That sounds like our man
Old Jan 6, 2005 | 03:38 PM
CabrioTurbo
either that or the mains and or big ends are buggered.
Old Jan 6, 2005 | 04:20 PM
flashpoint's Avatar
flashpoint
15 psi @ idle is just about ok much lower and I would be getting concerned
What concerns me more is the oil pressure above 3000 rpm, much below 40 psi and you run the risk of damage to the big end bearing on boost
Have had lots of fun and games with different oil pumps over the years from defiant manufactures, company’s. To cut a long story short the only pump to use is the original Ford one.
Question, did you have good oil pressure when you first fitted the new pump?
Steve
Old Jan 7, 2005 | 02:36 PM
Rallyesport's Avatar
Rallyesport
The regular pump that Burton sells is not an original Ford item? What's the price of an original Ford pump?
Old Jan 7, 2005 | 02:56 PM
Wazzzer's Avatar
Wazzzer
Don't put even more fear into me!!
Old Jan 7, 2005 | 06:23 PM
flashpoint's Avatar
flashpoint
Genuine ford pump is going to cost you about Ł97 depending on which one you have
Steve
Old Jan 7, 2005 | 06:34 PM
John Laverick's Avatar
John Laverick
My engine runs about 80psi on cold start.......20psi on warm idle....and about 60psi at 3k if that helps
mint_s2
Sep 2, 2015 08:58 AM
YODI
Aug 30, 2015 01:12 PM
Adam-M
Aug 26, 2015 05:53 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
mrmann
Aug 20, 2015 11:24 PM
