timming cahian not belt?
Old Jan 30, 2010 | 10:07 AM
morto's Avatar
morto
Default timming cahian not belt?
hello all my wife has a mk5 fiesta with the engine that was designed by ford and yamaha, 1.3..
now i was going to change the cambelt and have been to EK Brakes who told me it doesent have a timming belt it has a timming chain, ive checked the engine number with the engine number from EK Brakes and they are the same , do these chains last the life of the car ?
andy
Old Jan 30, 2010 | 10:23 AM
utternutter's Avatar
utternutter
bullet proof, just keep the valve clearances in tollerance and it will be fine
Old Jan 30, 2010 | 10:29 AM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
andy
1.25 Zetec SE 16 Valve?
If so it's got a timing belt.
Like any black-top zetec the tappets need adjusting every 95000 miles or so as it hasn't got hydraulic ones.
Old Jan 30, 2010 | 10:30 AM
user 7082039239
BTW: The only chain driven engines in the Fiesta (apart from the OHV Kent/Valencia) are the 1.3 and 1.6 ROCAM OHCs in newer models (Mk6 and late Ka's)
steves24V's's Avatar
steves24V's
yamaha engine is the 1.25 or 1.4 these have belt's the 1.3 OHV / HCS engine has a chain and as above just check the valve clearances and change the oil and it'll last.
but check which engine you have as i'm not sure which you mean i have heard some people call the 1.25 a 1.3 before.
Old Jan 30, 2010 | 10:55 AM
martysmartie's Avatar
martysmartie
You don't have Zetec SE you have a 1.3 Endura-E (Same as KA) it has a chain and as said are stong engines.
Martin
Old Jan 30, 2010 | 02:06 PM
RichieST's Avatar
RichieST
If it rattles like benni's dick inside a whore, then it's the chain driven 1.3 endura! If its the twin cam zetec 1.25, then its a belt
Old Jan 30, 2010 | 02:09 PM
botters's Avatar
botters
competant bodger
easiest way to spot is look for a plastic cambelt cover on the engine (drivers side) if it dont have one then it dont have a belt
simples
Old Jan 30, 2010 | 03:12 PM
morto's Avatar
morto
phoned ford this morn, gave them my reg plate they deff say chain!! but will double check anyway
thanks all
andy
Old Jan 30, 2010 | 03:23 PM
MarkyMark's Avatar
MarkyMark
if it has a silver metal rocker cover with endura e in green written across the top its a 1.3
Old Jan 30, 2010 | 03:33 PM
morto's Avatar
morto
will post pics its a duratec
Old Jan 30, 2010 | 03:35 PM
MarkyMark's Avatar
MarkyMark
didnt do duratecs on that year, not even branded duratecs on the mk5, what year is it,
Old Jan 30, 2010 | 03:51 PM
morto's Avatar
morto
here,s a pic so chain or belt
ford and all numbers say chain??
Old Jan 30, 2010 | 03:56 PM
MarkyMark's Avatar
MarkyMark
for a start that isnt a mk5, its a mk6, still it is just a kent engine 1.3 rebranded as a duratec
yes it looks like a chain one
Old Jan 30, 2010 | 03:57 PM
morto's Avatar
morto
52 plate mk 6 , i thought it was a mk 5
Old Jan 30, 2010 | 04:00 PM
morto's Avatar
morto
thanks for all the info mate!!
Old Jan 30, 2010 | 04:14 PM
DangerousBryan's Avatar
DangerousBryan
that is not a kent engine. its a rocam 1.3 sohc. and it is chain driven.
Old Jan 30, 2010 | 04:19 PM
morto's Avatar
morto
the plot thickens!!
Old Jan 30, 2010 | 04:22 PM
MarkyMark's Avatar
MarkyMark
and what engine is the rocam a upgraded version of?
i say kent engine, as that is what the endura e basically is and therefore what the rocam basically is.
fords like to confuse things (as well as themselves probably)
Old Jan 30, 2010 | 04:44 PM
morto's Avatar
morto
your correct fella!! look at this from wikipedia
Zetec-Rocam Kent 1.0 L (999 cc)
1.3 L (1297 cc)
1.6 L (1597 cc) 2000–present SOHC
the family is kent
Old Jan 30, 2010 | 04:45 PM
morto's Avatar
morto
http://en.wikipedia.org/wiki/Ford_Zetec_engine#Duratec
Old Jan 30, 2010 | 05:45 PM
RichieST's Avatar
RichieST
The rocam 1.6 engine is what they use in the sport/street kas. My mrs has a 1.4 zetec mk6 fiesta, I know they do the 1.25, I never realised they did the mk6 with a 1.3!
Old Jan 30, 2010 | 06:20 PM
MarkyMark's Avatar
MarkyMark
they renamed the 1.3 rocam as the series name and duratec as the public name, and yes they come on the mk6 why i have no idea.
and yes your right the 1.6 in the street/sports are rocams, again why they didnt use the zetec 1.6 engine is beyound me, the 8v makes it drink more petrol which imo was noticable, i did hear the zetec se 1,6 fouled on the bulk head
Old Jan 30, 2010 | 10:52 PM
user 7082039239
It ain't OHV though so basically it has nothing in common with the Kent/Endura/HCS engine.
Old Jan 31, 2010 | 09:30 AM
RichieST's Avatar
RichieST
From Wikipedia :
In 2000, Ford of Brazil developed an improved version of the Endura-E engine, to compete with the classic Volkswagen AP engines. Basically, the Endura-E received a completely new aluminum head, with much less restrictive intake and exhaust, SOHC and peripheral improvements. Its camshaft is driven by a chain. As a result, this engine exhibits rougher behaviour, producing more vibration and noise. On the other hand, it has a superb torque output thanks to the addition of the Rocam (rollerfinger camshaft) feature.
In 2003, the Zetec-Rocam engine was introduced in Europe, but labeled as Duratec 8v, for the SportKa and StreetKa models. Later a 1.3 L version was also released as an option for the standard model, but the European versions of the engine are produced in the South Africa plant.
So the Rocam engine comes from Brazil!
Old Jan 31, 2010 | 10:16 AM
DangerousBryan
the early engines have the cam in the block,over head valves and pushrods. as seen in mk1/2 escorts,early ka's and earlier fiestas. the rocam came out in about 2003 and has 1 overhead camshaft in the head and hydraulic tappets. came in 1.3 and 1.6. the engine in the picture is a rocam, is chain driven and it will last the lifetime of the engine so do's not need changing. much prefer the 1.25 zetec's though
so the only thing it has in common with the earlier one is the block.
Old Feb 1, 2010 | 06:27 PM
morto's Avatar
morto
some brilliant info here lads, i was told it was the yamaha engine when i bought it from a main dealer as well, but funny thing is when i took the plugs out they said ngk and ford on them so thats another reason i thought it was the 1.25 engine ? i also could not work out how it has hydrolic lifters ? but now i do
andy
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Nov 1, 2015 06:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
