zetec turbo head gasket, MLS or standard?
Old Jan 16, 2010 | 08:08 AM
my-first-rst's Avatar
my-first-rst
tokey smurbo
Default zetec turbo head gasket, MLS or standard?
hi all,
head gasket has gone on my zetec turbo
at the min im using a standard fibre type gasket, but im thinking of using the later blacktop MLS gasket?
would this be better than a fibre gasket?
cheers
steve
Old Jan 16, 2010 | 08:41 AM
zetaboostboy522bhp's Avatar
zetaboostboy522bhp
yep! same hadgasket used on wrc focus , and mine is fine on 500+bhp. and cheap as chips
just buy a genuine ford multilayer headgasket
cheers paul
Old Jan 16, 2010 | 09:23 AM
crazycage's Avatar
crazycage
cheers paul
so you dont run a cometic gasket then?
Old Jan 16, 2010 | 11:45 AM
zetaboostboy522bhp
no standard ford multi layer gasket with standard headbolts , torgued then to 110 degrees (standard 90 degrees) ians says torgue to yeild , and hes never had any probs, the only prob is when running very high boost when the head starts to lift, then ian advice is 11mm or 12mm stud conversion which is what iam going for.
cheers paul
Old Jan 16, 2010 | 02:27 PM
my-first-rst
tokey smurbo
are all later blacktop head gaskets the same? as i went to fords they said theres a early or late version but i assumed the early one was normal fibre one?
very helpfull info hopefully this one will last
Old Jan 16, 2010 | 03:50 PM
crazycage's Avatar
crazycage
cheers paul
strange ! i would of thought they would know things we dont i mean why do you think they make them.
p-s couldnt help it....
Old Jan 16, 2010 | 03:55 PM
crazycage's Avatar
crazycage
Originally Posted by my-first-rst
hi all,
cheers
steve
you will have to cc your engine mate because the standard fibre gasket is 1.6mm thick and the std focus one is only 0.6mm you might be better off with the st170 gasket as its 0.9mm and there both good for well over 500hp and both only about Ł30 .
Old Jan 16, 2010 | 05:12 PM
my-first-rst
tokey smurbo
is the st170 gasket the same fitment then?
tbh its a budget engine with a spaer plate to lower the compression so i wont bother goin all out on it as i have another engine that im building proerly now i know how well they perform
Old Jan 16, 2010 | 06:35 PM
my-first-rst
tokey smurbo
thinking about it i cant use a st170 gasket as mine is only a 1.8
Old Jan 16, 2010 | 06:42 PM
crazycage's Avatar
crazycage
just use a blacktop steel 1.8 gasket then mate.
robnock
21
May 13, 2019 05:29 PM
3i Jim
Nov 20, 2015 05:12 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
