GT2554r on 1.6CVH
Old Jan 4, 2010 | 03:49 AM
szabyk RST's Avatar
szabyk RST
Default GT2554r on 1.6CVH
My question would be
what RPM spool up to a 1.6 CVH?
8.2:1 CR
stage 2 (16psi)
big valve ported head
I want to use street
pressure all RPM (2000-6500)
thanks
you your help
Old Jan 4, 2010 | 11:08 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
won't see boost till 3000rpm, maybe a little later depending on what stage2 really infers as all turbo centres have different definitions.
Old Jan 4, 2010 | 11:13 AM
morph's Avatar
morph
8.2:1 CR
stage 2 (16psi)
thanks
you your help
If the cars fully mappable then Yes you can expect the turbo to come in early but it wont be able to hold out upto 6500 probably 5000-5700rpm max.
if on mfi then not too sure.
also you may not need to run 16psi boost depends on what power you was after?
Old Jan 4, 2010 | 03:50 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i misread your post, sorry, yeah a GT2554 should boost as low as 2000-2500rpm, but as above i'd eexpect it to be alittle restrictive over 6000rpm.
probably better to aim for a GT28 variant instead.
Old Jan 4, 2010 | 04:29 PM
Antti O's Avatar
Antti O
edit: nothing.
Old Jan 4, 2010 | 05:29 PM
szabyk RST's Avatar
szabyk RST
I do not want more 200-220BHP
street should not be more
I do not want to 28R
Old Jan 4, 2010 | 06:17 PM
morph's Avatar
morph
gt2554r will easily makes that!
but then you can get that from a stage 2 t3.
jamieRST
Apr 27, 2009 09:12 PM
rsvmad1
Dec 19, 2008 09:58 AM
cosworth87
Fiesta RS1800/RS Turbo
Apr 9, 2008 08:23 AM
bonus_boy
41
Jan 31, 2008 09:02 PM
bonus_boy
Dec 29, 2007 09:09 PM
