steamcleaning enginebay
Old Jan 1, 2010 | 02:47 PM
StephTell's Avatar
StephTell
Default steamcleaning enginebay
Right then, I'm going to do some work on my Jeep soon and I want to clean the enginebay/engine prior to opening the engine up.
A pressurewasher didn't seem such a good idea but how about getting to work with a steamcleaner? Hardly any water is used and I'm pretty sure it will blow all the crud of my engine....?
What says you?
Old Jan 1, 2010 | 04:10 PM
matts1's Avatar
matts1
there is a thread on how to do it, maybe in the detailing section. You can do it with a pressure washer but need to do some prep and use common sense.
Old Jan 2, 2010 | 12:45 PM
A proper STEAM cleaner will do wonders where a pressure cleaner won't be anywhere near as good.
I've never bothered with doing anything prior to steam cleaning been lucky and had no problems, other than the odd dizzie cap having moisture inside.
Old Jan 2, 2010 | 01:12 PM
RichieST's Avatar
RichieST
Cover up things like distributor/air intake/alternator with a bag and you should be ok, don't direct it straight at electrical things like fuse boxes/ign leads etc and it should be alright! It is a 4x4 so should be more resilient to water ingress than any other car i would have thought?
fatboyz
16
Sep 18, 2012 06:10 AM
cfoster
158
Jun 8, 2007 04:41 PM
Magnex20011
Mar 18, 2007 05:35 PM
filthyrichie
Feb 4, 2006 01:42 PM
~nomad~
May 26, 2005 11:00 PM
