Focus gear lever
Old Dec 24, 2009 | 01:59 PM
daddybairns's Avatar
daddybairns
Default Focus gear lever
has any one got pictures of gear lever set up
Old Dec 24, 2009 | 02:34 PM
woolford's Avatar
woolford
??? how you mean set up????
Old Dec 26, 2009 | 09:56 AM
daddybairns
the return spring how its fitted
Old Dec 26, 2009 | 02:32 PM
woolford's Avatar
woolford
wont it say in haynes?
Old Dec 26, 2009 | 03:01 PM
daddybairns
No it doesn't. It only really covers the transmission for the 1.8/2.0l models which is slightly different.
Old Dec 26, 2009 | 03:02 PM
daddybairns
I have the 1.6 with the iB5 transmission
Old Dec 26, 2009 | 05:35 PM
fiestamk2's Avatar
fiestamk2
i have the same set up.if you explain to me what your on about mate i will have a look out side tomorow for you
Old Dec 27, 2009 | 11:29 AM
daddybairns
I am trying to find out how to fit the gear lever return spring so it goes back into the third forth slot properly. The haynes manual doesnot seem to cover this procedure or give a clear picture/breakdown of the parts cheers mate
Old Dec 27, 2009 | 02:00 PM
fiestamk2's Avatar
fiestamk2
is this gearbox end or inside the car
Old Dec 27, 2009 | 03:08 PM
daddybairns
bottom of gearstick I am led to believe
Old Dec 27, 2009 | 03:14 PM
daddybairns
Old Dec 27, 2009 | 03:23 PM
fiestamk2's Avatar
fiestamk2
what made you play with it any way
Old Dec 27, 2009 | 03:29 PM
fiestamk2's Avatar
fiestamk2
you need to give more detail possibly with pictures then i can tell you
Old Dec 28, 2009 | 12:59 PM
daddybairns
I have not yet played with it but problem is gear lever does not centralise as it should so third gear sometimes difficult to find.
Old Dec 28, 2009 | 01:08 PM
fiestamk2's Avatar
fiestamk2
so you have had nothing apart yet.if its only sloping to one side its nothing serious.when you take it apart it will become obvious what it is
Old Dec 28, 2009 | 01:09 PM
daddybairns
OK thanks
Old Dec 28, 2009 | 01:13 PM
woolford's Avatar
woolford
mine does this on my 1.8.. doesnt look hard just not got round to it yet
Old Dec 28, 2009 | 01:24 PM
daddybairns
cheers mate will attempt it when stores open tomorrow
Old Jan 3, 2010 | 05:59 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
Here's the 'how to' guide. http://www.fileshost.com/download.php?id=BD3CE4EB1 very straight forward. About £4 for the spring but use some grease on it when installing it. Found the code for the spring: FINIS 1142069 quote that number to ford and they'll know the part you need.
TPM961
Jan 15, 2018 10:50 AM
talon1
Sep 15, 2015 10:27 AM
Flateric_2002
Sep 15, 2015 08:41 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
Adam Graham
Sep 6, 2015 06:04 AM
