Anyone had issues with Burton Power Oil Pumps? Also Oil pressure problem?
Old Dec 9, 2009 | 06:42 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Default Anyone had issues with Burton Power Oil Pumps? Also Oil pressure problem?
I am having a bit of trouble with my Escort Cossie (T25) . I have an oil pressure problem, which is a bit confusing? From a cold start, it takes about 5-6 seconds to build oil pressure, which then registers on the gauge and turns the dash light off. The car is then fine, as the cold reading is off the top of the dash gauge (as it should be, the oil pump is a burton high pressure 5 bar pump) while the car warms up. As it gets warmer, the oil pressure gradually drops off (as the oil gets thinner I imagine) until at idle (approx 850-900RPM) , it is off the bottom of the gauge, the followers rattle, but the oil light does not come on. As soon as you put any RPM on the engine, the oil pressure rises quickly and the followers quieten down.....The car is on running in mineral oil, but I can't see that causing a problem??
The engine is a fresh build, and everything is brand new (shells, pistons+rings, followers etc etc), everything was measured and in spec. The only thing I can think could be the problem is the Burton Power oil pump? I have heard storys of the relief valve sticking slighly open, allowing the oil to drain back out of the system? Has anyone else had problems with a Burton pump?
Old Dec 9, 2009 | 06:54 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I can't help you but i hope you don't kill your engine
Steve
Old Dec 9, 2009 | 07:34 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
had one exactly the same in last week on the same pump.
exactly as you decsribed
Old Dec 9, 2009 | 07:37 PM
RUPERT THE BIG HAIRY BEAR's Avatar
can u not tell him how u fixed atleast then lol rather than just tease him
Old Dec 9, 2009 | 07:39 PM
Asturias2's Avatar
Asturias2
Burton do sell some rubbish tbh,I very nearly bought a pump off them but went for the genuine updated one instead from WGM.
Old Dec 9, 2009 | 07:41 PM
JTECH James
Passion for Fords!
wasnt in for that, but i strongly advised it was investigated
Old Dec 9, 2009 | 08:08 PM
RWD_cossie_wil
So you recon a new pump would sort it James? Where is best to get a small turbo 5 bar pump from?
Old Dec 9, 2009 | 08:10 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
you only need a standard pressure pump
Old Dec 9, 2009 | 08:11 PM
JTECH James
Passion for Fords!
we didnt do much investigation on it, but its a real coincidence ..
his was a fresh motor aswell
mechanic28's Avatar
mechanic28
hate burtons with a passion
Old Dec 9, 2009 | 08:33 PM
lacey's Avatar
lacey
i cant understand why people still have trouble machining these parts when all it takes is abit of tlc and someone that enjoys there job to get them right. Imo . I machined oil pumps for the prodrive mondeo and mct , mountune and shit loads of other top works teams along with 1000s of fast road boys over 10 years so i know its not hard to get it right
Old Dec 9, 2009 | 08:34 PM
105epwr's Avatar
105epwr
i had a faulty burton pump on a x-flow i built,this was a hp/hc pump and it wiped the crank out on the dyno but burton said its not the pump...i must of left swarf inside the motor......
so i fitted another crank,shells and a different std pump and then went on to make 148bhp.
Old Dec 9, 2009 | 08:35 PM
RWD_cossie_wil
I just seem to remember that other people had probs with burton pumps in the past? Where does small turbo pumps then?
Old Dec 9, 2009 | 08:42 PM
forevaford's Avatar
forevaford
right, i had a problem with a 4x4 cosworth high pressure pump. on examination it had a crack in the pump body,consequently inducing air into the pressurised oil system and playing my tappets up lol.
my syptoms was (also on a fresh engine) toisy tappets when warm, and 6-8 seconds to build oil pressure when shut down. actual oil pressure when warm was ok ish (1.8bar) even if you thrashed it the tappets didnt shut up, after inspection of the pump i found the crack, the pump was new aswel. anyway changed the pump and it was fine, job done. i know its a different pump to what you have described but im just making you aware of my similar symptoms and my field of fix.
mart
Old Dec 9, 2009 | 08:47 PM
RWD_cossie_wil
Cheers for the info Mart, still points at the oil pump
Old Dec 9, 2009 | 08:48 PM
aviran_rsturbo_israel's Avatar
412whp
i have a burton power oil pump
never had any trouble with it...
Old Dec 9, 2009 | 09:07 PM
mark n lou's Avatar
mark n lou
i am having problems with a burton pump in my pinto.
fresh engine built, fitted last weekend.
on initial start up, after spinning up with drill through dizzy drive, recorded 160psi briefly before it blew a core plug out from behind the timing cover.
fixed this, and re-started with a different gauge. blew seal off oil filter and deposited oil on drive.
was ticking over at 105psi.
removed sump/cross member to get at pump. refitted old pump and everything was fine. (70psi at revs)
returned pump to burtons for a refund. should not be a problem, but i dont think they are going to repay me for sump gasket, oil filter, 4 litre of oil and 6 hrs labour, which i have asked them for. still waiting to hear back.
have since heard of a few other people having problems too with burton pumps.
update.----
heard back from burtons today.
very apologetic. refunding me for pump and sump gasket.
sending me 4 litre of oil and a filter, for next oil change.
adding a trade discount to my account to compensate for the labour.
Old Dec 9, 2009 | 09:34 PM
RichieST's Avatar
RichieST
Do Burton's make their own pumps then or are they sourced from some place else?
There was a thread on here a couple of days ago about a fresh engine build with a dodgy pump, wonder if that was a Burton's too?
Old Dec 9, 2009 | 09:41 PM
RST's Avatar
RST
Plus one!
Old Dec 9, 2009 | 10:37 PM
RSTurboSI's Avatar
RSTurboSI
I got a Pump from them last time i rebuilt the engine. It broken down and stopped feeding Oil into the head, that was just after 62 miles. And that was running the dam thing in. went to Norris and he sorted me one.
Ring Oli or Karl @ Norris. 01773 836274
Old Dec 9, 2009 | 10:41 PM
scoooby slayer's Avatar
scoooby slayer
just get it out and check it dont risk it pal. hope its an easy fix for ya.
Old Dec 9, 2009 | 10:57 PM
smartrs's Avatar
smartrs
now i'm worried i've just re-build mine using a new high pressure pump but not from burtons (although i nearly brought one from there) and i hink my oil pressure may be down although my followers are as quiet as a mouse just think i have a dodgy cheap oil pressure gauge
Old Dec 9, 2009 | 10:58 PM
rst in breaking's Avatar
rst in breaking
i had one on my zt, went from holding 5 bar, towed the car then had nothing????? took apart and gears had eaten themselves and engine was swarf free
Old Dec 10, 2009 | 01:58 PM
RWD_cossie_wil
Anyone else?
Old Dec 10, 2009 | 02:02 PM
B13 JUS's Avatar
B13 JUS
Originally Posted by RWD_cossie_wil
Anyone else?
i'm sure ford still sell them. my mate bought one a few months back for his 4x4 saph and they gave him the wrong one.
i think it was the small turbo oil pump they gave him.
Old Dec 10, 2009 | 03:12 PM
JamesH's Avatar
JamesH
Sounds like the pump to me
Old Dec 10, 2009 | 04:22 PM
D11AKS's Avatar
D11AKS
hp pump from burton allmost killed my engine fresh built real pain in the rs swapping it over after 10 miles then all was fine
got refund on pump but didn't make up for all the gaskets and time
Old Dec 10, 2009 | 05:21 PM
ECOS95's Avatar
ECOS95
Was anything wrong with the original pump? if not I'd put that back in before it all goes horribly (expensively) wrong.
Old Dec 10, 2009 | 05:53 PM
So lesson learnt,dont buy a oil pump from Burton.
Why do some people hate Burton power for.
Old Apr 21, 2013 | 08:40 PM
gticlassique's Avatar
gticlassique
the same story for me , fit a burton power high pressure oil pump on my 1600 cvh and at the start , the pressure was to low under 30psi
i bought another one , i fit it , and after 10 miles the pump is broken
engine fresh rebuilt with all parts new
the pump after 10 miles
i don't know why burton power continue to sell this parts ?
Old Apr 22, 2013 | 08:00 AM
mk22door's Avatar
mk22door
Fart of the Purniture
I was just recalling the same information from my memory.
Oh, that was an old post
Old Apr 22, 2013 | 07:18 PM
gticlassique
burton power answer :
" Hello,
We have removed this from our Facebook site, can you please contact us through sales@burtonpower.com for any problems with parts. Please find attached the fitting instructions for this oil pump.
This sort of damage is caused by a fitting error, it is not a faulty pump. we sell lots of these and do not have a any problems with these.
regards Ian "
lol
big_Rad
Sep 15, 2017 09:36 AM
Dubs44
Aug 21, 2015 02:42 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
track.focus'd
Aug 12, 2015 05:53 PM
