Boiler help?
Old Dec 29, 2004 | 07:34 PM
Stoo's Avatar
Stoo
Default Boiler help?
Right,
If the Central heating is working i.e The radiators are warm ect that should mean the system is working right?
But....i have NO hot water comming from the tap's Cant figure this out.Its a Combi boiler.I should have hot water if the heating works,right?
Old Dec 29, 2004 | 08:25 PM
stevedohc16v's Avatar
stevedohc16v
The radiator and hot water circuits are totally different m8, the radiators can be working ok but the hot water side of things could be bust, this is usually due to a faulty pressure sensor in the hot water circuit which senses a pressure drop in the water supply when you open a tap and then operates a divertor valve which re-routes the water flowing round your radiators to a heat exchanger to heat your water.
Easy way to tell whats faulty is to watch the main flames while someone operates a tap, if they go out then the pressure sensor is ok and the valve could be faulty, if the flame stays on then the pressure sensor isn't seeing a pressure drop.
However combis have a lot of electronics within them and some of these could be knackered, thats when it gets expensive and hard to track the problem down.
HTH
Steve
Old Dec 29, 2004 | 08:28 PM
TIFF's Avatar
TIFF
Chasing Radders
As above
But also make sure that the switch on the boiler is on Central Heating AND Hot Water
Old Dec 29, 2004 | 08:41 PM
Ginge !'s Avatar
Ginge !
just finding my feet
no comment
Old Dec 29, 2004 | 08:43 PM
TIFF's Avatar
TIFF
Chasing Radders
Old Dec 29, 2004 | 08:45 PM
Ginge !'s Avatar
Ginge !
mine also has red lights beside em too when there on
fook me that was a cold shower, good job the house was warm when i got out
Old Dec 29, 2004 | 08:52 PM
Stoo's Avatar
Stoo
Cool,cheers
The thing is i dont have a switch for both,only one or the other but i assume one of these will do both
When its set on radiators and you just click it to 'on' all is well but if you turn it to the tap symbol it just seems to turn off,is stops humming( )
Fooked if i know
Old Dec 29, 2004 | 08:53 PM
Stoo's Avatar
Stoo
Can i also say the water pressure was reading zero but i fooked about with the valve thing to get it back between 1 and 1.5 as thats what the thing say's to do.Only instructions on the bloody thing
Old Dec 29, 2004 | 08:57 PM
TIFF's Avatar
TIFF
Chasing Radders
the heating will be fine a 1.5 bar
I hope you vented all the radiators when you refilled it
Old Dec 29, 2004 | 09:09 PM
Stoo's Avatar
Stoo
Err....nope
What do you mean?Your worrying me now
Old Dec 29, 2004 | 10:44 PM
TIFF's Avatar
TIFF
Chasing Radders
at the top of each radiator is a little square ended screw, if you undo this it will let the air out of the radiator and allow water into it, which it needs to get hot.
Do this to all the radiators and keep topping the pressure back up as you let the air out
Old Dec 30, 2004 | 06:32 PM
Stoo's Avatar
Stoo
Nice one Cheers
Old Dec 30, 2004 | 06:48 PM
TIFF's Avatar
TIFF
Chasing Radders
Is it working now???????????????????????
Old Dec 30, 2004 | 07:56 PM
Mrs Ginge's Avatar
Mrs Ginge
he might have frozen to death
geoffxr4
Jan 12, 2007 07:27 PM
danneth
Nov 4, 2006 07:46 PM
RSCAT
73
Feb 21, 2005 04:02 PM
Christian and Beccy
13
Oct 18, 2004 04:53 PM
