ecos amal valve ?
was giving the car a clean today, when have a look over the engine bay noticed the amal valve fitted, its identical to the one on my old ERST, 3 outlets and an electrical conector, one to the wastegate, one the the acctuator then the 3rd one is venting to atmos? is this correct ? if not where should the 3rd outlet go to ?
any help much apprecited
sean
sean
Dont know why you didnt ask me mate, Joe removed the Escort one as he sets it up with the saff one for Rejetting purposes i think...
Its his preferred way to do it.
A few other tuners do it that way too. No big deal.
I imagine Joe did that to youres too Glen.
PassionFords Creator
The P8 has closed loop boost term control and as such has targets to aim for when dealing with programmed in gear boost control for midrange spikes etc. This only works on the original 2 port valve. Dont remove it unless you are no longer running a P8 ECU.
just found out the car has been converted to l8, so im guessing this means the amal valve is a saff one, ill need to take car to my tuner to let him see it,
