How can I identify 1.6 engine?
Old Oct 28, 2009 | 09:55 PM
Barnes's Avatar
Barnes
Default How can I identify 1.6 engine?
Hi All,
First post to the group.
I took ownership of a 1.6 2006 Focus Climate on Monday. I have to say it's a lovely car to drive.
I was curious to know which type of engine it has. I believe there are 2 types and 100 bhp and 115 bhp.
Could you tell me the easiest way to find the details or identify the unit please.
I haven't got the log book as the dealer has sent it to be updated and to be honest I never asked him which engine was fitted.
Am I also right in thinking the lower power unit has a cam chain and the 115 a belt?
Many thanks.
Old Oct 29, 2009 | 05:39 PM
RichieST's Avatar
RichieST
New shape focus? Should all be chain cam. There will be a sticker somewhere in the engine bay with the power output, its on the cam cover on the mondeos, look there!
Old Oct 29, 2009 | 05:52 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Usually there's a big "16" cast on the side of a 1.6 block. Unless that stopped at some point... But with modern engine bays it can be hard to see the block
Old Oct 29, 2009 | 06:23 PM
OldDan's Avatar
OldDan
You can check by looking at the cam cover. If it is pretty much completely flat it is 100.
If there is a raised section naer the cam cover I'd say it was a 115 Ti-VCT engine?
Either way, none of the petrol 1600s are chain driven. They are belt.
Old Oct 29, 2009 | 06:28 PM
white4x4cos's Avatar
white4x4cos
Dubble cam sensors and two solenoides on the cover would be the 1.6 115bhp.
Old Oct 29, 2009 | 10:54 PM
Barnes's Avatar
Barnes
Thanks for the replies.
I will have a look tomorrow but if the 1.6 has a timing belt rather than a chain I may get it changed as a precaution.
Old Nov 3, 2009 | 07:34 PM
martysmartie's Avatar
martysmartie
No need to especially as its a fairly new car, the Ford recomendation for a change is 100,000 miles although not to be taken as gospel.
Sometimes on higher millage cars the tensioners have been known to fail.
Martin
JoeyBoyden
Jan 4, 2024 02:36 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
