Suggestions for oil pressure gauge?
Old Dec 25, 2004 | 11:16 PM
Wazzzer's Avatar
Wazzzer
Default Suggestions for oil pressure gauge?
I'm after an oil pressure gauge, doesn't have to be fancy or anything, electric or the other (whichever is easiest to plumb in) but it needs to have all the necessary bits to fit it straight on if poss, anyone got any suggestions?
As cheap as poss as I'm skint after Xmas
Old Dec 25, 2004 | 11:28 PM
tiny's Avatar
tiny
Try rally design race tech are cheap enough,though imo autometer is the
one 2 go 4 but twice the price, u gets what u pay 4 . real steal sell the autometer gauges but some of the traders on here should do them aswell
Old Dec 25, 2004 | 11:36 PM
Wazzzer's Avatar
Wazzzer
Like the look of the Race Tech gauges, cheers for that, might give them a ring in a few days and see what bits I'd need to plumb it straight in
Old Dec 25, 2004 | 11:57 PM
escort1989uk's Avatar
escort1989uk
try nomad they are good gauges
Old Dec 26, 2004 | 12:04 AM
RS Grant's Avatar
RS Grant
Made in Scotland
Nothing on eBay?? Either private sales, or from an eBay Shop??
Usually some pretty good stuff floating about there for much cheapness.
Cheers,
Grant
Old Dec 26, 2004 | 12:29 AM
DazC's Avatar
DazC
I advise AGAINST a capilliary pressure guage for fluids. Get one with an electrical sender unit....
Old Dec 26, 2004 | 10:57 AM
Wazzzer's Avatar
Wazzzer
Whys that Daz? In case they leak?
Just looking through ebay and found a nice electrical white faced one for Ł22! Who would sell the T piece to screw in so I can keep the dash warning light as well?
Old Dec 26, 2004 | 11:03 AM
AJC's Avatar
AJC
yes, they leak, had it happen to two of mine, oil every where, dash carpet,
all over head unit, its just not worth it. get an electric one like DAZC says...
Old Dec 26, 2004 | 01:21 PM
markk's Avatar
markk
i have to disagree , ive had too many bad experiances with elecric sender uinit dealing me duff info when i realy needed it , like OH FUCK NO OIL PRESSURE in the middle of a stage
but , my guages even tho they are capillery are very accurate , unlike most electric units , but i never fit the nylon pipework that comes with the guages i always use ptfe with nylon overbraid and pukka fittings not teh cheap brass push on crap items
Old Dec 26, 2004 | 01:30 PM
Ian M's Avatar
Ian M
i just fitted a higher value oil pressure switch, because i really didnt fancy a face full of hot oil and i know electrical senders can be misleading.
Old Dec 26, 2004 | 01:58 PM
Hardeep_Singh's Avatar
Hardeep_Singh
i've got the nomad one which uses an electrronic sender inplace of the original oil switch, works fine on my car and easy to fit
Old Dec 26, 2004 | 04:08 PM
jaimesdna's Avatar
jaimesdna
ive had a bad experience with electric as they can be miss leading. cant see why a capillary 1 would leak if fitted properly. thats what im goin 4 when the cars back on the road
Old Dec 26, 2004 | 06:19 PM
DazC's Avatar
DazC
I just prefer having oil in the engine and not in a pipe next to your leg.
A burst pipe or guage (as has been known to happen) is not good on a road car to clean up. A competition car isn't too bad, just wipe the excess off and the rest is anti-corrosion!
As it happens, my new engine management monitors oil pressure and I can set it to flag up a warning if it drops to a certain level or cut the car out completely if it drops even lower..
Old Dec 26, 2004 | 10:00 PM
Wazzzer's Avatar
Wazzzer
Right I'm going for an electrical one now, just torn between these two... opinions?
PSI or BAR?
Old Dec 26, 2004 | 10:03 PM
L33 BYT's Avatar
L33 BYT
Where they from wes?
Old Dec 26, 2004 | 10:07 PM
Wazzzer's Avatar
Wazzzer
ebay
want the link to them? Both from the same bloke...
L33 BYT's Avatar
L33 BYT
Please
Old Dec 26, 2004 | 10:34 PM
Alvyn's Avatar
Alvyn
m8s got an electric senders type and as soon as his ignitions on ie b4 the engine starts turning it's reading oil pressure in the engine and once he had really low oil and the gauge was showing but when we pulled up the top end (cam followers) were well noisey on start up(Cossie) checked the dip stick and there was none on the stick so personal choice comes into play I think
Old Dec 27, 2004 | 12:23 PM
markk's Avatar
markk
DazC,
all for the price of a Ł20 oil pressure guage , ill have one !!!
Alvyn,
a pressure guage is not designed to tell you when you need or dont need oil , by default it will do this , but thas only when it has no more lubricant to decide what pressure it at .
i can also never understand why people remove the oil pressure lamp and replace it with a guage
what is the easiest thing to see if you suspect a problem ? its not looking at a guage ( that aint accurate anyway cause you paid less than the price of gallon of oil for it) and trying to decide if its on 0.5bar or 1bar, whilst at speed going round a corner . all you need is a high pressure switch and a warning lamp.
Old Dec 27, 2004 | 03:49 PM
Wazzzer's Avatar
Wazzzer
I'll still be using my original dash warning light and the gauge
Think it might have to be the PSI one....
TPM961
Jan 15, 2018 10:50 AM
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
dombanks
Sep 21, 2015 08:38 PM
Si B
Sep 12, 2015 06:49 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
