oooopps there goes a new focus RS
I would be amazed if it was a fault from the factory that caused that accident. Sounds like understeer followed by lift off oversteer ( or poor correction ) Bearing in mind the tyres are brand new and the owner wasnt used to the car/power etc
Sounds totally like driver error! after all he is never going to admit it is he
i work for bmw if we ever had a instance like this with a new bmw someone would be flown straight up to us from bracknell from bmw & tests would be carried out on the car.
If he is blaming ford for supplying a faulty car this will be investigated big time.
i work for bmw if we ever had a instance like this with a new bmw someone would be flown straight up to us from bracknell from bmw & tests would be carried out on the car. If he is blaming ford for supplying a faulty car this will be investigated big time.
Years ago the E36 had a problem of the steering column lower shaft (bulkhead to rack) failing. Result was that ALL E36's were recalled for a new lower column shaft fitting - Infact, BMW were so worried by this problem that still to this day the recall can be carried out on any E36 that hasn't had it done with BMW picking up the cost
its a lad on my local forum.... the car was investigated and found to have a problem with the "Hydroelectric brain part of the steering system" (his words not mine)
the fact ford are giving him another and a few extra pennys says it all for me!
luckily there was a copper behind him tho to back up his story for not giving it too much beans
how do u know if it has been replaced?
even though mines done 270k if i can get a free part for it the better
Phone your local dealserhisp with the last 7 of the chasis number they will tell you if its outstanding chances are its done as dealers got hammered by bmw if they had a car in & never done it.
Mr Broadside has bought a stunning 328i with full BMW history - only thing outstanding is the steering shaft upgrade/replacement according to my man at Sandal Huddersfield
We had done a oil service on a E60 530d last year never done a high pressure pump recall on it because the customer couldnt do without the car. We then got a letter from bmw saying if the engine failed due to the pump it would be down to us the dealership as we let it out without doing the repair. We done it pronto
one of on my friends has a blue rs, that had power steering pump failure before it was deliver to him.new pump fitted, you can see the damage on the radiator where it has been changed by the fraud garage.so far in 800 miles the warning light has appeared 4 times.
ahhh thats why i got a text saying if i knew anyone who who would be interested in his cozzie lol
Bloody hell thats shocking.I love my fords but i thought they would of had no faults with this focus rs.
that carnt drive a car ,lost steering at 40mph did he lose the brakes as well
not good
