advice on supercharged ST170 engine build?
Old Oct 7, 2009 | 03:24 PM
SVTyler's Avatar
SVTyler
Default advice on supercharged ST170 engine build?
I've been running the PowerWorks kit on my ST170 for a while with great success. I'm now needing to rebuild the engine. My goal is 250-300 whp with bulletproof reliability. I'll be fitting an overdrive crank pulley for more boost. I'll probably use a basic pistons/rods set up. I'm also interested in upgrading my valvetrain with cams and valve springs etc. Can anyone suggest cams to go with a supercharger? Should I keep the VVT? Any advice would be greatly appreciated!
Old Oct 7, 2009 | 04:02 PM
wirralphil's Avatar
wirralphil
https://passionford.com/forum/restor...e-for-now.html
Old Oct 7, 2009 | 04:21 PM
COCHYN's Avatar
COCHYN
As above, Tiny Will's your man
Old Oct 7, 2009 | 04:45 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
What sort of compression ratio are you looking to run?
Old Oct 7, 2009 | 07:42 PM
SVTyler's Avatar
SVTyler
I'm thinking around 9. But that is the kind of thing I'm digging for answers about. Like I said, my main concern is reliability and drivability.
Old Oct 7, 2009 | 09:09 PM
Big Will_'s Avatar
Big Will_
I would try and get it higher than that to be honest, 9.5:1 as a minimum for that sort of power.
Cam wise - i'm running around 270 degree duration with around 11mm lift. CAT Cams made my cams to my specs, however, i'm revving to 9000rpm as i've also built a short ratio gearbox...
I've also found the powerworks inlet manifold to be VERY restrictive, i found an improvement of over 30% in the flow figures by careful porting.
SmudgerByName
52
Jul 28, 2016 06:14 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
track.focus'd
Aug 12, 2015 05:53 PM
knight19770
Aug 4, 2015 12:36 PM
