are these common fiesta door problems?
weird one its a 2000 zetec s, interior light stays on, changed boot sitches on both tailgate and rear panel so its not them, unscred each front door pin tried to earth out the wire on the pin to body to check didnt make any difference
yesterday when you locked the car from drivers side it instantly unlocked, now when drivers door is open its constantly locking and unlocking but when doors just it just locks itself
any pointers??
lee
any pointers??
lee
Would say its a GEM problem, a module which controls most electronics things such as audible "Lights On" charm and central locking.
BTW earthing the wire on the body will actually complete the circuit and switch the light on as when you close the switch IE open the door this is all it does.
Martin
Martin
Does sound like a door isn't shut properly and thats why it can't be locked by CL although would think this would be a door lock problem on one of the two doors.
Does sound like a GEM fault as I said, with door switch when you take it out this will switch light off.
I would help you out if you want buy your not that local to me.
Martin
Martin
It doesn't have a GEM.
A friend of mine had a similar problem on a fiesta turbo, turned out to be corrosion/broken wiring within the wiring loom between door and body of the car.
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
