zetec turbo
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
The YB Cosworth engine is very efficient in relation to the Zetec, the Brake Specific Fuel Consumption is quite different, i can't remember the exact numbers from memory.
There are some Siemens injectors between the 55s and the 83s, they're 72lb from memory, i believe we've got a set on the shelf at MSD.
They should be a nice compromise for you.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
I run 83s for approx 400hp.
Only run at max 38% injector duty so there is plenty of scope to increase the power without the expense of new injectors.
Buy for the future
Buy for the future
how much are they??
