blanking the egr on focus 1.6 se
Old Sep 20, 2009 | 10:45 AM
fiestamk2's Avatar
fiestamk2
Default blanking the egr on focus 1.6 se
can it be done and is there any gains from it
Old Sep 20, 2009 | 11:26 AM
RichieST's Avatar
RichieST
Do they even use egr?
Old Sep 20, 2009 | 03:09 PM
fiestamk2's Avatar
fiestamk2
ive looked in the manual and it says there there on the 1.4 and 1.6 on the exhaust manifold.im gonna have a look later.i assumed that they all had one that was all
Old Sep 20, 2009 | 03:40 PM
You will see zero gains, unless it is faulty to start with, as it is only used under certain conditions to admit exhaust gasses back into the engine to keep the temperature down to lower NOX emissions.
Old Sep 20, 2009 | 08:16 PM
fiestamk2's Avatar
fiestamk2
thanks
Old Sep 20, 2009 | 08:28 PM
JamesH's Avatar
JamesH
If you remove EGR:
It can make cylinder pressure a LOT higher, therefore could cause you big problems. Not sure if it would effect MOT emissions as well.
Can make temps go either way, depending on the engine condition.
Not worth the risk for what is probably a small gain IMO!
Old Sep 21, 2009 | 09:33 AM
It doesn't affect pressure, other than the tiny lowering of pressure, it is not "on" at idle, it can ONLY cause a cooling effect, as it part fills the chamber with incombustible gasses, this being it's purpose.
The critical point is 1300 go over that and NOX goes through the roof, under they don't produce any amount.
Old Sep 22, 2009 | 07:04 PM
JamesH's Avatar
JamesH
Do you mean cylinder pressure? And it does NOT only have a cooling effect.
I will admit the changes are more extreme on just a normal turbo application rather than an NA.
But you are wrong.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
liamT74
Sep 23, 2015 10:24 PM
focuspower
Sep 19, 2015 08:27 PM
gcfcos
88
Sep 15, 2015 03:48 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
