dump valve
Old Sep 3, 2009 | 04:13 PM
mr_joe0606's Avatar
mr_joe0606
Default dump valve
hi guys. which dump valve to go for as mine is leaking i have a baileys at the moment what happens if i dont have 1.
thanks joe
Old Sep 3, 2009 | 04:24 PM
T28 RST's Avatar
T28 RST
Ok then
You wont have a gay noise
Old Sep 3, 2009 | 04:25 PM
mr_joe0606's Avatar
mr_joe0606
where does the vacum hose go from the end ov the dump valve cheers i dont want 1. propa chavvy
Old Sep 3, 2009 | 04:33 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Plug it, and tie it up out of the way.
Old Sep 3, 2009 | 04:54 PM
Scott-rs2k's Avatar
Scott-rs2k
for what its worth i got a forge one i am about to put on flea bay new there like £100 ish
Old Sep 3, 2009 | 04:57 PM
jamieRST's Avatar
jamieRST
thought dump valves were good cuz they keep the turbo spooled up between gearchanges
Old Sep 3, 2009 | 04:59 PM
Scott-rs2k's Avatar
Scott-rs2k
depends if its a vta or re-circ type etc i guess
Old Sep 3, 2009 | 05:12 PM
jamieRST's Avatar
jamieRST
and turbo chatter wears your turbo quicker
Old Sep 3, 2009 | 06:29 PM
cozmeister's Avatar
cozmeister
More boost Igor!
It doesn't keep it spooled up - anti-lag does that - the DV simply prevents the turbine stalling, hence, slightly decreased lag.
Sort of - in my experience a VTA one is better because the hot air isn't sent back to the air box.
Depends on the size of the turbo, and whether it's well maintained or already on its way out.
Old Sep 3, 2009 | 06:38 PM
Mr C's Avatar
Mr C
I would use a GGR GpA type with filter to stop dirt ingress on idle and replaceable diaphragm, this will stop ur turbo slowing up so much between gear changes. I have one for sale at £100posted UK
Old Sep 3, 2009 | 07:13 PM
jamieRST's Avatar
jamieRST
will it be ok on the 1.6 as its on ggr as for a cossy?
Old Sep 3, 2009 | 07:50 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
you need a twin piston one when using mfi, single or diaphragm will be fine for other applications.
pistons are better for higher boost and yes i have one on my rst cab and zvh efi xr2, helps reduce the lag when changing gears on aggressive driving as the turbo spins in the same direction, unlike when you don't have one it can stall and has to spool all over again.
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
rs_jim
Sep 19, 2015 08:41 PM
