Is 99 Degrees to HOT??
Old Dec 20, 2004 | 09:07 AM
zvhturbo's Avatar
zvhturbo
Default Is 99 Degrees to HOT??
I finally got my car fully up and running yesterday, left it running in the garage (heated) for about 2 hours.
The fans were cutting in at about 98 Degrees and cutting back off at about 88 Degrees.
Is this running toooo hot??
Can i get a fan switch to keep the temps a bit lower.
All temp figures were taken from the ECU read out on my laptop so should be dam accurate.
Matt.
Old Dec 20, 2004 | 09:10 AM
B19-TRB's Avatar
B19-TRB
Thats only a few degs higher than mine used to run!
98 was the highest i ever saw after i got things sorted! but i only ran 1 fan!
Old Dec 20, 2004 | 09:12 AM
CraigN's Avatar
CraigN
i dont let mine get to 90 lol
on track didnt go over 90 degrees thas on my cossie
and i was ranting it
zvhturbo's Avatar
zvhturbo
The fans cool it from 98 to 88 in about 25 seconds so do a great job, its just the fan switch doesn't cut in untill 98.
Thought that seemed a bit high.
Old Dec 20, 2004 | 09:15 AM
B19-TRB's Avatar
B19-TRB
that seems fine to me m8!
before my car had seen temps of 130deg! this is what happens when u got the wrong water pump on!
stripped i down & the head gasket was mint! replaced it anyway! cheers DOO
Old Dec 20, 2004 | 09:33 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Change the Thermostat to a sierra type this should cut in the fans before the temps reach 98c
Regards
Old Dec 20, 2004 | 09:36 AM
zvhturbo's Avatar
zvhturbo
I'm using the 82 degree thermostat.
Its the fan switch that cuts in so high.
Old Dec 20, 2004 | 09:39 AM
B19-TRB's Avatar
B19-TRB
I ran a kenlowe fan swtch & u could set that to come in whenever u wanted!
Old Dec 20, 2004 | 09:40 AM
churchy's Avatar
churchy
From: Out Shooting Burgelers, cause thats what Norfolk people do!!!
Thats probably about right. As long as the water don't boil, its fine.
Old Dec 20, 2004 | 10:17 AM
foreigneRS's Avatar
foreigneRS
Testing the future
i would run it cooler. it's all well and good seeing what it does at idle, but you need to know that it's not going to get to hot when on load, ad the earlier you bring the fans in the better.
i would change the fan switch to the cosworth one that comes in earlier (88/77).
see https://passionford.com/forum/viewtopic.php?t=77198
and you're unlikely to boil the water in a pressuried system that contains antifreeze.
Old Dec 20, 2004 | 10:38 AM
zvhturbo's Avatar
zvhturbo
So i want a 88/77 fan switch.
does anyone have the part number. or What model Cosworth does it go on?
Thanks ForeigneRS
Matt.
Old Dec 20, 2004 | 10:44 AM
Jon ERST S2's Avatar
Jon ERST S2
mine never ever went above 94 degrees. Generally less than that.
Old Dec 20, 2004 | 10:58 AM
foreigneRS's Avatar
foreigneRS
Testing the future
i did have the part number on a piece of paper in my wallet, but must've cleared it out.
it's fitted to all 2wd sierra cossies, don't know about 4x4 and escos as i believe that some models have a 2 stage arrangement on the twin fans (in series for half speed, and in paralel for full speed)
Old Dec 20, 2004 | 11:07 AM
Jim Galbally's Avatar
Jim Galbally
fook me my thermostat dont even open till 88degrees
Old Dec 20, 2004 | 02:49 PM
Hardeep_Singh's Avatar
Hardeep_Singh
zvhturbo - put on a 2wd cossie fan switch mate like foreigners said i have done the same, its a straight fit and you will notice the difference in temps but what i find is that once the fan kicks in, the temp never comes down enough for the fan to stop spinning, it hasnt been a problem though just somthing i have noticed, i run a standard erst rad and fan and standard erst thermostat from fords....... mine stays about 1/3 up the temp gauge
Old Dec 20, 2004 | 02:52 PM
Rhys's Avatar
Rhys
on the cossie it cuts in at 98C though since fitted my new alloy rad it never gets there unless its been idling for fookin ages!! Can remember with my std rad i only had to be stoped for 1min and the fans would cut in Now with a more powerful engine it runs shit loads cooler!
IMO get new rads peeps makes helof a difference
Old Dec 20, 2004 | 02:57 PM
I saw the title and thought you meant intake temperature!!!
Old Dec 20, 2004 | 02:59 PM
Rhys's Avatar
Rhys
LOL now that would be hot
Old Dec 20, 2004 | 03:08 PM
zvhturbo's Avatar
zvhturbo
I have a Pace Ally rad, 2 10" Kenlowe fans and a GRS intercooler.
The fans have no problem cooling the car, its just the fan switch cuts in so high.
Thanks for the help.
I will get a Cosworth fan switch.
Old Dec 20, 2004 | 03:10 PM
Rhys's Avatar
Rhys
Cosworth switch I got a new one on mine and it cuts in at 98C reading on secs so might be bit cooler at rad etc?
Old Dec 20, 2004 | 03:16 PM
zvhturbo's Avatar
zvhturbo
Mine is a new switch but i'm not sure for what car, i'm sure i brought a ERST switch, that cuts in at 98 as well, and cuts off at about 88.
Apparently the Cosworth switch should cut on at 88 and off at 77
Old Dec 20, 2004 | 03:23 PM
88 seems like a nice number for the fans cutting in.
Old Dec 20, 2004 | 03:40 PM
Jim Galbally
you could get yourself a nice adjustable one like what burtons/demon theives etc. etc. sell.
also your ECU might have a radiator fan activation facility, quite a few do
that way you can have it coming in/out EXACTLY how you want it
Old Dec 20, 2004 | 03:42 PM
zvhturbo's Avatar
zvhturbo
Yes Jim it does, but i don't know how to do that
I best read the manual tonight.
Old Dec 20, 2004 | 03:44 PM
foreigneRS's Avatar
foreigneRS
Testing the future
what rhys is seeing is because the temp sensor for the secs monitor is the ecu one in the head, and the fan switch is at the bottom of the rad.
of course the water in the head will be a lot hotter than at the bottom of the radiator, that's why you need such a low setting for the switch. the fan switch is put at the bottom of the radiator as it then only cuts the fans in when there isn't enough air movement over the radiator core tocool it. if you put it in the head, or on the top hose, it'd never cool down to the switch off point.
Old Dec 20, 2004 | 03:48 PM
zvhturbo's Avatar
zvhturbo
Both my Rad fan switch and the ECU water temp sensor are right next to each other in the head.
Will my 98 degree switch be ok then??
Old Dec 20, 2004 | 04:15 PM
Jim Galbally
just use the ECU
it'll be one pin to hook up and one setting to change
Old Dec 20, 2004 | 04:16 PM
Jim Galbally
wait a sec, why's your fan switch in the head?
Old Dec 20, 2004 | 04:17 PM
foreigneRS's Avatar
foreigneRS
Testing the future
if your fan switch is in the head, once the engine is under any under load the fan will probably never go off as the thermostat's job is to keep the engine hotter than (in your case) 82 degrees.
Old Dec 20, 2004 | 04:26 PM
zvhturbo's Avatar
zvhturbo
Sorry Jim not directly in the head, my temp sensor and fan switch are next to each other in the thermostate housing, which is bolted to the head.
Old Dec 20, 2004 | 05:47 PM
AndyRST's Avatar
AndyRST
Fit a 4x4 saff cossie fan switch They work alot lower temp range.
I have kicking about for my RST but didnt get round to fitting it durning the summer and so far havent needed it in the winter.
Old Dec 20, 2004 | 06:34 PM
Rick's Avatar
Rick
uou dont want them running too cold. Fans that come in early are stupid. Running it quite hot at idle is good for the engine.
Old Dec 20, 2004 | 06:59 PM
JesseT's Avatar
JesseT
B19_TRB:
Please share the information about the water pump.
Old Dec 21, 2004 | 06:06 PM
AndyRST's Avatar
AndyRST
whys that rick ?
Thought engines that ran too hot tended to stress hoses, water system head gasket etc ?
Old Dec 21, 2004 | 07:19 PM
Rick's Avatar
Rick
There is more pressure yes, but providing everything is in good condition, it'll be fine. Running an engine hot reduces wear and fuel consumption. If it's running at a decent temperature when crusing, getting hotter in traffic before the fan cuts in is no problem. There is no point having the fan cut in, and it fighting against the thermostat. I run a 92 degree stat in mine in the winter - better economy and hit heater.
Old Dec 21, 2004 | 08:45 PM
AndyRST's Avatar
AndyRST
just for reference my ST170 runs at 96 şc
Old Dec 21, 2004 | 08:51 PM
Rick's Avatar
Rick
On my shopping list is a proper water gauge with warning to replace the std guessometer
Chas
Oct 5, 2015 07:13 PM
PeterLucas
Sep 21, 2015 11:36 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
Marino
Sep 12, 2015 11:10 AM
