cossie vvt cams ++ other things
here are some pics of my vvt cams++
has anyone seen these before???? http://img.photobucket.com/albums/v3...s/IM000935.jpg http://img.photobucket.com/albums/v3...s/IM000939.jpg the spec on the cams are a bit wilder than BD 16 and are supposed to work between 2500 rpm to 8500 rpm
the other picture is my rs500 block vith liners an some sort of wireringing
oil pressure thru a two way valve that is controlled by a ecu picking up signal on rpm. The cams are from an old escort cossie that was used in touring car in 93/94 season.
Looks good, look forward to seeing the results
The subject of VVT cams on a cossie were being debated on here last week (between Stu & SECS IIRC?)
Originally Posted by CraigN
looks interesting
notice how no tuners have put there opinions on this post yet
PassionFords Creator
looks interesting
these cams were up for sale in germany for a couple of years ago.pricy bit of kit.probably dont need it but its acool thimg if it works.as i said in the first post they are a bit wilder than BD 16´s
you could make it much more drivable low down with wild things happening when u open it up, but with the likes of modern ecus and software, this appears to be able to be done without th need for them. "unless" there is a significant hike in umph with the use of them.
JoeyBoyden
Jan 4, 2024 02:36 PM
muz
Aug 16, 2015 12:57 PM
Roosie
Aug 13, 2015 07:40 PM
vvt
