CVH Engine Removal Advise Please
Old Aug 24, 2009 | 08:59 AM
jedi0_3's Avatar
jedi0_3
Default CVH Engine Removal Advise Please
Morning all.
Got to take out my EFI CVH engine, have done it once before as per Haynes manual but has anyone else got any hints or tips to speed job up?
Should I drop engine down to get it out as per Haynes or can I go up?
Head off or on, etc.
Thanks
Old Aug 24, 2009 | 09:17 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i find going up easier if you don't want to remove shafts and box etc, just undo all hoses/starter/alternator/radiator/exhaust manifold and turbo and lift the lot out upwards.
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
what car is it in? in the mk2 fiestas escorts ect if we are lifting just the engine we normaly leave the box in with a jack under the bellhousing side of the box and useing a hoist lift the engine out the top......takes about 45 mins
Old Aug 24, 2009 | 10:25 AM
jedi0_3's Avatar
jedi0_3
Its a Mk4 Escort XR3i EFI.
Had a feeling going up was better, I assume there is room in the engine bay then to slide gearbox away from engine.
Old Aug 24, 2009 | 11:03 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
you can't really move the gearbox, but the engine will pull away enough once the box is tilted up along with the engine and pulled forwards slightly when also twisting the engine to the fron t alittle.
Old Aug 24, 2009 | 11:06 AM
jedi0_3's Avatar
jedi0_3
Is it then a bitch to get gearbox re-attached when refitting?
Old Aug 24, 2009 | 11:07 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
it can be arsy, but genereally doesn't take more than a few minutes if you're on your own, easier with a friend to twist the engine about to get it aligned though.
Old Aug 24, 2009 | 12:24 PM
taz1787's Avatar
taz1787
Escort Cabriolet Owner
one tip would be to remove bonnet completely whilst removing engine as it gets in way of crane etc
Old Aug 24, 2009 | 04:22 PM
jason t's Avatar
jason t
i done a engine on my series 2. gota take the bonnet right off otherwise it be a struggle. i left my gearbox in the car, i slackend the gearbox mounts rite off and woz easy gettin it in and out, but im a ford tech and wud of found it impossible wiv outa hand mate. not a bad job, recomend getting the front end high as u can off the floor
Old Aug 24, 2009 | 05:15 PM
jedi0_3's Avatar
jedi0_3
Thanks for all the help guys-really appreciated.
JoeyBoyden
Jan 4, 2024 02:36 PM
borboyous
Aug 22, 2015 11:17 AM
Bosch
Aug 4, 2015 05:14 PM
knight19770
Aug 4, 2015 12:36 PM
lockie
Jul 31, 2015 10:03 PM
