Polishing bare alluminum???
Old Aug 18, 2009 | 07:28 AM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
Default Polishing bare alluminum???
Not sure if this is in the right section or not?
I have some Genuine 1973 Porsche fuchs wheels.
Im trying to detail them, with some polishing.
They have been polished some time ago and since keyed up and painted.
But after stripping paint the mirrored finish is still visiable
My thoughts are to go over with say 1500-2000 wet and dry then metal polish??
I may make up a spinner from an old hub so i can have the wheel spinning, as I think this will speed the job up signifgantly!
Anyone eles have experience before I start, as i dont want to damage/make worse the finish I have so far!
Old Aug 18, 2009 | 07:50 AM
AustenW's Avatar
AustenW
Do all the hard work with wet and dry before you try the polishing mop as this will save you alot of time
Go in stages from 1000 grit up to 2500 depending on how rough the surface is
Old Aug 18, 2009 | 10:22 AM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
reckon i can start on about 1500 or 2000, as said it was pre polished, just been painted over and lightly keyd.
Old Aug 18, 2009 | 12:49 PM
Mr.T's Avatar
Mr.T
i used commandant 4 and unipol for my truck wheels. bare alu.
From this
To this
Old Aug 18, 2009 | 01:18 PM
andy-rs's Avatar
andy-rs
whats commandmant4 and unipol and what process do you use? cheers mate
Old Aug 18, 2009 | 01:51 PM
Mr.T's Avatar
Mr.T
Right i thought they sold it in the uk to. Commandant is a cleaner. Gets the rough layer off. With unipol you can polish the alu after. Works perfectly. No sanding needed cos you use Commandant for it. But don't know if they have it for sale in the uk tho. Unipol is like 28euro for a liter. And commandant 14euro or something.
Just wash the wheels. Get all the dirt and sand off and get busy with Commandant. After that you polish it with unipol and ...well youve seen the pics. Those wheels didnt got a cleaning for 6 months. On the pics i took about 1 hour per wheel.By hand. using a drill speeds up the proces tho
Old Aug 18, 2009 | 01:53 PM
Mr.T's Avatar
Mr.T
Old Aug 18, 2009 | 02:06 PM
Mr.T's Avatar
Mr.T
Btw after doing this ones. you only need unipol for maintenence
Old Aug 18, 2009 | 09:20 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
Thanks for that, Yes we have unipol over here, Ill see if my paint shop sell it tommrow as ive got to pop in for some primer and hardner anyway
Old Aug 18, 2009 | 09:26 PM
Mr.T's Avatar
Mr.T
No prob
It is expensive tho. Well here it is. But you don't need much.
Old Aug 19, 2009 | 10:45 AM
Polished Bliss's Avatar
Polished Bliss
Official Car Care Sponsor
The Blackfire metal polishing system also works very well when sanding haze removal and mirror polishing is required on bare aluminium surfaces. See here for full details...
Heavy Cut Compound - http://www.polishedbliss.co.uk/acata...nd-engine.html
Fine Cut Polish - http://www.polishedbliss.co.uk/acata...sh-engine.html
Mirror Finish Polish - http://www.polishedbliss.co.uk/acata...sh-engine.html
Mc5506
Oct 5, 2015 09:57 PM
DavidK
Sep 27, 2015 02:55 PM
caprixpack
Sep 25, 2015 07:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
timsrs
22
Sep 24, 2015 08:14 PM
