Polishing bare alluminum???
Shizzle My Nizzle
Not sure if this is in the right section or not?
I have some Genuine 1973 Porsche fuchs wheels.
Im trying to detail them, with some polishing.
They have been polished some time ago and since keyed up and painted.
But after stripping paint the mirrored finish is still visiable
My thoughts are to go over with say 1500-2000 wet and dry then metal polish??
I may make up a spinner from an old hub so i can have the wheel spinning, as I think this will speed the job up signifgantly!
Anyone eles have experience before I start, as i dont want to damage/make worse the finish I have so far!
Do all the hard work with wet and dry before you try the polishing mop as this will save you alot of time
Go in stages from 1000 grit up to 2500 depending on how rough the surface is
Right i thought they sold it in the uk to. Commandant is a cleaner. Gets the rough layer off. With unipol you can polish the alu after. Works perfectly. No sanding needed cos you use Commandant for it. But don't know if they have it for sale in the uk tho. Unipol is like 28euro for a liter. And commandant 14euro or something.
Just wash the wheels. Get all the dirt and sand off and get busy with Commandant. After that you polish it with unipol and ...well youve seen the pics. Those wheels didnt got a cleaning for 6 months. On the pics i took about 1 hour per wheel.By hand. using a drill speeds up the proces tho
Official Car Care Sponsor
The Blackfire metal polishing system also works very well when sanding haze removal and mirror polishing is required on bare aluminium surfaces. See here for full details...
Heavy Cut Compound - http://www.polishedbliss.co.uk/acata...nd-engine.html
Fine Cut Polish - http://www.polishedbliss.co.uk/acata...sh-engine.html
Mirror Finish Polish - http://www.polishedbliss.co.uk/acata...sh-engine.html
Mc5506
05-10-2015 09:57 PM
DavidK
27-09-2015 02:55 PM
caprixpack
25-09-2015 07:53 PM
timsrs
22
24-09-2015 08:14 PM
