what fuel pressure regulator?
hi, what fuel pressure regulator am i going to need for my s2 running efi? its on ofab, stage 2 chip and beiges, am i right in saying the standard one wont work properly?...
it needs to be approx 3.5 bar or mine did to run and fuel correctly.
you need a gauge to set it up and even then if you don't know your fueling levels then your taking a big risk, without visiting a tuner.
i'm using the standard frst regulator and its seems ok at the moment thats all i can really add.
tis nothing fancy mind just a gauge fitted in line on the supply side of the fuel rail.
Like I said not the tidiest but doesn't leak and isn't under any stress creating any awkward angles etc for my fuel feed.
I will create a bracket i think and tidy up the braided lines as they have frayed but its functional.
SMILER258
Sep 28, 2015 09:04 AM
Dubs44
Sep 19, 2015 06:31 AM
