gear change is like stirring soup
craig89
hi my s2 gear change is slack and has loads of free play in it im told that that is a common problem but can be fixed i had a look on ebay and found a bush and spring kit
ebay number 380129608624
is this the correct thing for the job and is it fairly straight forward to fit any tips
cheers for help, craig
See this simple to follow guide to sort out the problem
http://www.zetecinside.com/xr2/gearbox.shtml#linkage
i got a b&m quickshift, but it was still sloppy when i got the car, so i had a look and all the bolts holding it on was loose and the bush on the selector link going to the gear box was proper loose so i got the pin out and put a nut and bolt with washers on, and thats done the trick for now
TPM961
15-01-2018 10:50 AM
Adam Graham
06-09-2015 06:04 AM
