Boost Problems?
Old Jun 30, 2009 | 08:34 PM
Matt-Turbo's Avatar
Matt-Turbo
Angry Boost Problems?
My RST when im reving up above 3000rpm it hits like a fuel cut and sometimes it revs up spot on. My acuator wasnt holding alot of boost could that be the promblem?
Old Jul 1, 2009 | 01:17 PM
notroubleclubber's Avatar
notroubleclubber
Back In The RS Game!
possibly - whats your boost set at? Has it got chipped ecu? Need more info m8.
Old Jul 1, 2009 | 06:40 PM
Matt-Turbo's Avatar
Matt-Turbo
Its a t34 turbo its EFI set up and it running cossy managment. Its set at 10psi at the min the guy that was setting it up said it was weak thats why he only set it till 10psi cause he said if he screwed it the whole way in he was only gonna get 15 at the max. Wat else could be causing it man? Its a really bad cut out.
Old Jul 1, 2009 | 08:44 PM
notroubleclubber
Could be an electrical problem? Spark blowing out? Check to see your gaps are correct - if the guy was setting it up wouldnt he be able to tell you?
Old Jul 1, 2009 | 09:37 PM
Matt-Turbo's Avatar
Matt-Turbo
Yeah mite take it to him and see wat he says. There is a set of spark plugs not long in it NGK iridium. Wats the best plugs to use? I had just NGK ones in it and they didnt last very long till it started missin a bit pretty much the same thing this time only this is a bad miss. Y would it be goin thro plugs so much?
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
