adjustable tracking control arms this the norm?
Old Jun 16, 2009 | 08:52 PM
col93saphcos's Avatar
col93saphcos
Default adjustable tracking control arms this the norm?
hi everyone,fitted adjustable tca's this morning,went to get camber set at a garage to find one of them would give 2 1/2 dergees negative camber as minimum!!well 2 1/2hrs later after trimming bits off it got set,so my £45 4 wheel aglinment then cost £108.68,well pissed off, if i new they were shite wouldnt have bought them,also could of trimmed them this morning before fitting,will phone company tomorrow a complain,but is this normal?surely a monkey can weld a bit in the right place!col93saphcos
Old Jun 16, 2009 | 08:54 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
no overly good tbh!
what camber are you running now? i ran 2 degs
Old Jun 16, 2009 | 08:56 PM
dojj's Avatar
dojj
Resident Wrestling Legend
did you measure the centre's before fitting?
the welding isn't exactly the same beacuse they are cut and chut as individual items, not matched pairs, which could explain the inconsitacies
Old Jun 16, 2009 | 09:02 PM
col93saphcos
Originally Posted by JTECHSAFF
no overly good tbh!
wanted 1 1/2 neg camber ended up with 1degree 40seconds on both that was the other one in as far as it would go to get that,col93saphcos
Old Jun 16, 2009 | 09:05 PM
col93saphcos
didnt think i had to check anything as fitted them and drove to get set up,kind of assumed company that made them knew what they were doing,mmm maybe not!col93saphcos
Old Jun 16, 2009 | 09:25 PM
RS-Leigh's Avatar
RS-Leigh
I have the same problem mate, only one of mine went to 2 deg 30 and the other was on the stops at 3 deg neg. I wanted 2 deg but had to set both to 3 deg.
On track at combe so will see how they feel.
Leigh
Old Jun 16, 2009 | 09:31 PM
iansoutham's Avatar
iansoutham
OCD Victim
The difference is 10 minutes of adjustment between what you have and what your ideal setting was.
Just a quick question... did you set both arms up correctly and evenly before installing them? If either are not set the same initially, there will be a difference in total adjustment level.
Old Jun 16, 2009 | 09:32 PM
Mike1's Avatar
Mike1
I had some off Brom and they were set at 1 degree 30 minutes both sides no problem. He used to do a more expensive sort that had replaceable balljoints ( off a Fiesta I think? ) but I had the cheap ones.
Old Jun 16, 2009 | 09:49 PM
dojj's Avatar
dojj
i think he's on about the lack of adjustability in the planes he wants, as in it won't actually get to those measurements before the adjustment runs out/is unsafe
Old Jun 16, 2009 | 09:54 PM
col93saphcos
yes,happy with what its set at,yes both were set up evenly when i put them in,problem seemed to be that the threaded bits were bottoming out against each other not letting it go shorter,garage said they have had to do this before,col93saphcos
Old Jun 16, 2009 | 09:57 PM
NUTS RuS's Avatar
NUTS RuS
Is the car lowered ?
Old Jun 16, 2009 | 10:06 PM
dojj's Avatar
dojj
if it's bottoming out and it's only such a small ammount, could you not just remove them, grind a tiny bit of metal off and then get them set up again correctly?
col93saphcos
thats right,the shortest one would go im sure was not far from 3degrees negative camber,the other as said 1degree 40,shudder to think how much more negative camber could of been possible.
but i would of thought they would be made so the shortest setting was about the same length or nearer the lenght of a standard one,surely cant be that difficult to make a jig and do them right,mean both were different,col93saphcos
Old Jun 16, 2009 | 10:12 PM
col93saphcos
thats what took so long he had to keep taking it to bits to cut more off,3 times i think before he got it,was good that the garage did do it,only went in to get it set up and ended up being on there ramps most of afternoon,mind you i was charged for it,lol,he was into his fords luckily enough,col93saphcos
Old Jun 16, 2009 | 10:15 PM
col93saphcos
no,its on ggr spec springs of standard ride height,col93saphcos
Old Jun 16, 2009 | 10:28 PM
NUTS RuS's Avatar
NUTS RuS
Our jig is set at when fully wound in they offer OE length.
They are designed to offer negative camber adjustments, but im getting feedback of late of people needing positive putting back on.
Sometimes this can be down to the vehicle being lowered (so they already have a negative setting) and no extra positive can be introduced to pull it back.
In that case a shorter adjuster is required which we can do quite easily and if thats the way the market is going I will get it looked at.
For interest were where yours from ?
Old Jun 16, 2009 | 10:58 PM
col93saphcos
from you,lol,col93saphcos
Old Jun 17, 2009 | 01:43 AM
Micky's Avatar
Micky
I know from reading this thread that some folks have had trouble with TCA's off Tony,but as Tony said,most adj TCA's are fitted to give negative camber,so thats the way their made from the factory!!But its great to see that Tony is taking all views on board,so all the customers will be happy.Just want to say that Tony is one of the good guys,and will go out of his way to help anyone out.
In my opinion Compbrake and MEF offer a fantastic service!!! Micky
Old Jun 17, 2009 | 06:25 AM
Mr RS500's Avatar
Mr RS500
I would have put quite a bit of money on the fact they came from COMP BRAKE , lol
Old Jun 17, 2009 | 07:54 AM
col93saphcos
[QUOTE=Micky;4214392]I know from reading this thread that some folks have had trouble with TCA's off Tony,but as Tony said,most adj TCA's are fitted to give negative camber,so thats the way their made from the factory!!But its great to see that Tony is taking all views on board,so all the customers will be happy.Just want to say that Tony is one of the good guys,and will go out of his way to help anyone out.
In my opinion Compbrake and MEF offer a fantastic service!!! Micky[/QUOTE
they were bought to give negative camber i know that!!
never realised they only went from 3 degree negative to more negative,so is every one using them running really aggressive camber??probably not.plus tony has already said there standard size at their shortest.
if they were correct and more expensive it would actually work out cheaper!lol
col93saphcos
Old Jun 17, 2009 | 09:05 AM
dojj's Avatar
dojj
seconded
he's even gone as far as saying that if more peole want more adjustment he'll look into getting it done, which is more that what you might expect from some places
Old Jun 17, 2009 | 09:08 AM
bud-weis's Avatar
bud-weis
Football Cwazy
Mine were perfect from Tony, he is so helpful that im sure a quick phonecall would have had it sorted!
Old Jun 17, 2009 | 09:26 AM
NUTS RuS's Avatar
NUTS RuS
Ok at 1am this morning I was on the case to sort out what was happening as I had had about 3 people mention this to me over the last month.
The problem has been traced and rectified as of 10am this morning.
Due to a change in supplier the radius of the track control arm's ball joint end is now bigger and this was not accounted for in the jig, so the arms were getting cut off 10mm to long
Thanks for bringing this to my attention Col and it has now been corrected.
If anyone who has had them recently and is struggling to get them to fit CompBrake will post out free of charge parts to make them correct or they can be returned for a replacement.
Drop me a PM with invoice details and I will ensure this gets sorted.
I have also asked them to change the jig so they do offer positive adjustments (for people with lowered cars who need to pull the arm in from standard) so again from the next batch all arms will offer 10mm minimum positive adjustment as well as the full negative adjustment.
Tony
Old Jun 17, 2009 | 09:33 AM
Mike1's Avatar
Mike1
Tony
That is a sign of a conscientious supplier in my opinion. Good work Tony!
Old Jun 17, 2009 | 11:55 AM
col93saphcos
apoligies to tony,they were bought direct from compbrake website,which i assumed was tony's,did mean to buy them from tony,so sorry
both tony and compbrake have been very conciensous and helpful in getting it sorted out,thanks for explanation tony.
just i was 2hrs from home at a garage to get it set,so didnt have their phone number to phone them,so at that point was kind of needed garage to do what they needed to do,also didnt know if this was normal,is set now so should be fine,happy with the product just didnt expect the extra hassle and cost,col93saphcos
Old Jun 17, 2009 | 12:07 PM
STUCOS's Avatar
STUCOS
Col gives a phone mate.how does the car feel now you have the beam set up
cheeRS stu
Old Jun 17, 2009 | 12:34 PM
mk3cosworth's Avatar
mk3cosworth
mine were exactly the same had to get them machined them down at my expense, glad to hear you have sorted it now
Old Jun 17, 2009 | 02:28 PM
Mr RS500's Avatar
Mr RS500
So what is going to happen about my totaly shit Bias pedal box then Tony ????
I contacted Steve as you asked , he then gave me the contact number for the fella who makes them for Comp Brake , and still after 5 messages left to him i have yet to recieve a call back to explain why my pedal box hits the steering column
Paul
Old Jun 17, 2009 | 02:57 PM
NUTS RuS's Avatar
NUTS RuS
I'll come up and take a look Paul if you tell me when your there this week
Neil only modified what you sent in, so if we can take a look at it in your shell and then to double check it on another shell or car if you have one, I can get to the bottom of it.
I take it the doors open ok on this one
Just let me know when your there
Old Jun 17, 2009 | 03:23 PM
RaZoR's Avatar
RaZoR
So what would be the correct length to get full adjustment? I measured my tca's now and they are 5-6mm different in length also.
Old Jun 17, 2009 | 03:27 PM
NUTS RuS's Avatar
NUTS RuS
That depends on your ride height RaZoR.
Old Jun 25, 2009 | 02:21 PM
KSA-Cossie's Avatar
KSA-Cossie
Would mine have come from this batch tony ?
IainRS1700T
Sep 25, 2015 06:44 AM
155lee
Sep 23, 2015 01:27 PM
martynhomer01
14
Sep 23, 2015 12:23 AM
rsturbo27
Sep 5, 2015 05:08 PM
