Remote ISCV housing......
Old Jun 16, 2009 | 08:40 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Default Remote ISCV housing......
Where can I get one of these?
Old Jun 16, 2009 | 08:44 AM
Depending on what valve you want to use, could make one, or to fit an easier to use iscv use a omega etc one, where it has simply just a 1/2" pipe either side to attach as you like anywhere then.
Old Jun 16, 2009 | 08:46 AM
Christian and Beccy
#1 in Spelling Club
I have a Cossie ISCV. I've seen the one in the Webcon catalogue, which would be fine. Suppose I should call them really.
Old Jun 16, 2009 | 09:31 AM
The remote housing that the std cossie iscv fits is from a lacia delta intergrale, but is used on a lot of other lancia's.
The Youth.'s Avatar
The Youth.
I'm sure some alfa's had the other end to fit a cossie one into, the ones with the pipe connections at 90 degrees to each other, similar to the omega one
steve
DixieTheKid
11
Jun 6, 2020 11:20 AM
jessie_rs
62
Aug 6, 2019 09:27 PM
RSmark84
Sep 13, 2015 01:29 PM
cozzy jeff
Sep 12, 2015 04:32 PM
