Polished Bliss: Mercedes SL500...
This was done last month but I've only just found time to catch up on some write ups. It wasn’t one I was planning on showing but I figured it would be a good one to do in the end so we start from the correction stage, with the car in for 3 days...
Looks pretty good in that pic already, but if you look closer you know it's not good news when you can see buffer trails when there's no direct light on the paintwork...
Turns out the owner had previously requested a valeter to give the car a machine polish but as you can see they didn’t do the best job, as can be seen further when the Sun Gun comes out to play...
Luckily the paint readings on all metal and plastic panels were healthy enough to allow me to go hard at the paint, using a 3M Compounding Pad @ 2000rpm's with Fast Cut Plus & Ultrafina with a drop of one of Gloss-It's new products:
This is my favourite product at the moment, it reduces dusting, primes pads nicely and totally transforms some polishes, especially the Gloss-It ones via Rotary and sticky paint is now just a slight inconvenience
Test section before:
During:
After:
50/50 on the bootlid shows the contrast in clarity of the paintwork:
This is typically the kind of random scratch that was left as it was too deep to safely polish/sand out:
Menzerna's new 80mm pads (loving these just now too!) were used for the tighter areas:
Before:
After:
The vents were removed to enable me to fully correct the surrounding areas:
Before:
After:
50/50 on the N/S wing:
Fully corrected:
50/50 on the door:
Rear 1/4 before:
After:
Before:
After:
Before:
After:
Roof:
Before:
After:
The side grills/fins/what ever you want to call them were a bit tarnished so while they were off I cleaned them up with some Brilliant Metal Polish and a CCS Polishing Pad:
Before:
Products used:
After:
Light before:
After Menzerna 203S:
Some of the worst areas such as the sideskirts and majority of the bumpers were corrected with a Gloss-It wool pad:
These areas were then refined with Menzerna 203S and the rest of the car was done with Menzerna 85RE.
Pictures from then on were few and far between due to a 1:30am finish on the 2nd day so this was the rest of the process before the final pics:
LSP - Top Inspection wipe down followed by Zym0l Vintage.
~Exterior Glass - New Glass Sealant currently on test.
~Interior Glass - Eimann Fabrik Clear Vision.
~Tailpipes - Wire Wool and Raceglaze Alutech followed by BF Metal Sealant.
~Wheels - Blackfire Metal Sealant.
~Tyres - 3 coats of Gloss-It Signature Tyre Gloss.
~Engine Bay - Aerospace 303 Protectant.
Interior:
~ Thorough Hoover.
~ APC wipe down.
~ Leather cleansed and fed with Raceglaze twins.
~ Mats lightly shampooed with Autosmart Brisk.
~ Shuts with Prime Strong
~ Rubber Seals with Raceglaze trim dressing.
Final wipe down with Werkstat Carnauba Glos and here's the result of 35 hours work :thumb:
Thank you for taking the time to read
Clark
During:
After:
Before:
After:
Before:
After:
Fully corrected:
50/50 on the door:
Rear 1/4 before:
After:
Before:
After:
Before:
After:
Roof:
Before:
After:
Before:
Products used:
After:
Light before:
Interior:
~ Thorough Hoover.
~ APC wipe down.
Clark
http://www.polishedbliss.co.uk/acata...dvice-faq.html
Yes i have and i sort of understand what i need the products to do but not sure what products i need to buy to do what i want them to if you know what i mean lol
I could do with someone who knows there stuff making a simple shopping list for me or having a look at a list i think i need.
Here's my attempt.
wash= megs hyper wash
clean= megs quick clay kit
polish= megs g220, Menzerna polish triple pack
protect= blackfire wet diamond
wheels= megs wheel brightner
Here's my attempt.
Clark
Great work as always bud
When are we gonna see the New Focus RS write up?
Alps Pacino
Looks good to me bud, i have the Blackfires, leaves a great finish.
It would be worth emailing Rich at Polished Bliss and he will get back to you faster with your chosen selection, has helped me loads in the past
Alps Pacino
Ye i might drop him an email see what he says as i could do with getting the integra sorted cause it's been stood for nearly 2 years and the paint is flat as fuck and full of marks which looks worse than it is cause its black
http://www.polishedbliss.co.uk/acatalog/contact.html
A combination of bad washing techniques and very poor rotary polishing skills and products is most likely; getting a flawless finish with a rotary polisher is not easy, hence why so many people get it so badly wrong.
Aye; given that you have three cars with three different paint types, you are going to need a bespoke kit for the machine polishing work. E-mail me details about the condition of the cars and their colours, and I'll get back to you on Monday with a suggested shopping list and working routine to follow for all of them. E-mail address on this link...
Cheers Mark
Mc5506
Oct 5, 2015 09:57 PM
caprixpack
Sep 25, 2015 07:53 PM
timsrs
22
Sep 24, 2015 08:14 PM
