Cossie clutch cable
Old May 20, 2009 | 09:31 PM
Barry R's Avatar
Barry R
Default Cossie clutch cable
Is the clutch cable the same as any other sierra?
Turns out my cable has stretched causing the slipping
Need 1 asap
Old May 20, 2009 | 09:35 PM
155lee's Avatar
155lee
they have genuine cables on ebay for Ł30.
Old May 20, 2009 | 09:40 PM
Barry R's Avatar
Barry R
They might have but I need 1 in the morn hence asking so I can go to
me shop and buy 1
And I aint gonna pay Ł30 for a lousey cable lol
Old May 21, 2009 | 05:49 AM
A stretched cable is not going to cause slipping, quite the opposite, if stretched enough it will cause drag, think Ford still do them, 3 door same as 2wd sapphy, Ł30 isn't bad anyway, stop being a tight wad!!
Old May 21, 2009 | 10:10 AM
Barry R's Avatar
Barry R
So that wouldnt cause the slip then
My pedal is as high as it will go
And melted on the turbo
Now the clutch slips but only every now and then
mainly when its wamed up
Old May 21, 2009 | 10:17 AM
siscossie's Avatar
siscossie
3-door moonstone
Mine did the same mate had to make a heatshield to protect the cable, dont think the cable will cause the slipping thou.
Old May 21, 2009 | 10:19 AM
Barry R's Avatar
Barry R
I got a heat sheild now
So looks like a new clutch and cable then
Old May 21, 2009 | 10:21 AM
siscossie's Avatar
siscossie
3-door moonstone
Afraid so mate, its not too bad to do yourself did mine in a hour just get a good clutch. Woodford motorsport could get you a cable out by 2mrow
Old May 21, 2009 | 11:35 AM
The slipping is most likely caused by either a worn out/weak diaphragm, or very worn friction plate, worst is it may have oil on it if the rear crank seal is leaking.
The cables are a doddle to do around 15 minutes, put box end on first, then just lift pedal, this will cause the ratchet to open, then with thumb push ratchet foprward enough to slip cable end in, release pedal push a few times job done.
Old May 21, 2009 | 03:27 PM
Barry R's Avatar
Barry R
Ive done a few mate its just weird its not slipping at all today
and the padal is a bit lower
Old May 22, 2009 | 07:21 AM
Mike1's Avatar
Mike1
- my Mk2 RS2000s used to do the same - they'd snap as you get a tight spot on the cable. Usually caused by the lubricant/cable sleeve getting fried by where it passed close to the exhaust manifold/heat source.
Not had it so far on my Sierra so have a look at how it's routed on a concours one next time you see one at a show just to make sure you're not missing a clip or something. Or as you say, get some of the Agriemach sleeve or a heat shield
Old May 22, 2009 | 09:03 AM
Barry R's Avatar
Barry R
I got a heat sheild on it now its weird i went up a steep hill yesterday at 30 put it
into 5th gear and nailed it didnt slip atall it just slips when it wants to
Any ideas why
Old May 22, 2009 | 03:25 PM
frdsmth9's Avatar
frdsmth9
I recently changed my clutch cable, as my old one had a kink in it. One day the pedal just went to the floor, and I discovered the kink and changed the cable. Since putting in the new cable, my clutch has never felt the same. So having friends trying to adjust it for me, I just knew it felt different. So I decided to take it to my mechanic, and let him have a shot at adjusting it. He told me that there was little he could do, and that there was no more adjustment to be had, he felt that there was something internally wrong with the clutch assembly itself. My question is, could it have been the clutch itself that caused the old cable to kink? The reason I ask, is that I never experienced any clutch trouble at all prior the old cable kinking.
Old May 22, 2009 | 03:31 PM
saph cos rob's Avatar
saph cos rob
swindon rsoc
unless the clutch ratchet has done up too tight? dont really know how they work tho... ive just changed mine to hydraulic clutch and no longer need my clutch cable and it was new at start of the year.......
Old May 22, 2009 | 03:45 PM
Barry R's Avatar
Barry R
I just bought 1 now Rob
Whats the hydraulic clutch feel like
Old May 22, 2009 | 03:52 PM
saph cos rob
swindon rsoc
1000000000000 times better.... my clutch was very heavy before as i run a 4 paddle cermatalic clutch, with the cable it used to get heavier the futher down i pressed the peddle, at shows by the time i had qued to get in i had a numb leg!!, now its lighter and feels the same all the way to the floor......
Old May 22, 2009 | 04:14 PM
Barry R's Avatar
Barry R
how much does it cost to convert then
Old May 22, 2009 | 04:28 PM
saph cos rob
swindon rsoc
under Ł200 i payed for all the bits, but i done it the cheat way with the slave cylinder.... used a wilwood 'pull' type as its basically a clutch cable replacement
Old May 22, 2009 | 05:28 PM
I did a hydraulic on my dads 4i, cost less than Ł100 but this one had a master cylinder(not reservoir)mount welded to the pedal box, then reservoir mounted on bulkhead under bonnet.
As said there is no comparison, and I find exactly as above person, it feels more like a heavy throttle pedal than a clutch!!
Old May 22, 2009 | 05:43 PM
Barry R's Avatar
Barry R
Sounds like to much work
Old May 22, 2009 | 06:18 PM
saph cos rob
swindon rsoc
nah not at all
like i said i used the easy option for the slave cylinder, pedal probally would have been even lighter if i used the hydraulic thrust bearing type ...
Old May 22, 2009 | 06:22 PM
Barry R's Avatar
Barry R
Yep deffo to much work for me
Old May 23, 2009 | 07:00 PM
Barry R's Avatar
Barry R
Sorry mate youre wrong I put a new cable on today and Ive been driving it non stop for about 5 hours and didnt slip once
Aint that strange
Old May 23, 2009 | 07:41 PM
cozzy940's Avatar
cozzy940
mine did same without heatshield clutch cable cover overheats and shrinks biting on cable so clutch never fully disengaged on mine which caused slipping, heatshield + new cable now no probs
Old May 24, 2009 | 06:34 AM
A strethed cable did not cause the slipping, the fact was it was sticking on and not fully returning to rest caused the slipping.
Old May 24, 2009 | 06:42 AM
cozzy940's Avatar
cozzy940
sorry thats what i meant wasnt stretched
Old May 24, 2009 | 09:18 AM
Barry R's Avatar
Barry R
The cable had stretched by half an inch it was returning all the way back we did check that but now its lush
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
muz
Sep 30, 2015 08:29 AM
