Bag of poo Sapphire
Old May 15, 2009 | 04:04 PM
judgey-c's Avatar
judgey-c
Default Bag of poo Sapphire
Hi all.
Bought a 1990 Saff cos with L6 management and 2(!) engine looms.
Removed one loom and installed one very good one.
Now the car runs,but quite lumpy and my old mechanic ear suggests rich.
Anyway,what is the big cause of rich running?Twirling the screw on the L6 seems to make no difference (which way is lean and which is rich??)
Quite enjoying messing with it to be honest,but having it running a bit better would be good for moving it about so I can weld it etc.
BTW cambelt and pulley changed and the rotor arm position is spot on as is the crank and cam timing.
Cheers Colin
Old May 15, 2009 | 06:43 PM
It would be a good idea to replace all the sensors first, unless new, especially the CTS.
Old May 15, 2009 | 06:58 PM
saph cos rob's Avatar
saph cos rob
swindon rsoc
the new loom youve installed, is it a 4x4 loom?
Old May 15, 2009 | 07:02 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Take it to msd for a full checkover, they will tell you whats fucked
Old May 15, 2009 | 07:16 PM
WongRS's Avatar
WongRS
give the chip a quick woble in the ECU, mine came loose and my fueling went berserk!
Old May 23, 2009 | 08:06 PM
judgey-c's Avatar
judgey-c
Right!
Its a 4 wd loom but 2wd engine and an l6 ecu.The tps seems to be a PF01.
A while ago it spewed lots of oil out of breather and I got a bit worried.I have been changing the rocker gasket tonight (its split) and found the oil level is right up the dipstick and smells of petrol from the weeks of getting it going with a fucked loom.
Looks like I've found some of its probs!!!!Basics Judgey,basics!!!!!!!!
Cheers for replies!!!!
Old May 24, 2009 | 01:35 AM
jon@work's Avatar
jon@work
Check that the wiring for the water temp sensor (2 pin connector at the back of the head on the passenger side) is OK. Unplug it and pull back the rubber boot and give it a good looking over.
If the wiring looks OK, remove the ECU hairbrush and measure the resistance between pins 11 and 29. Should be around 4500 ohms (engine cold) to 950 ohms (engine warm). If resistance high, change sensor or check wiring again.
Old May 24, 2009 | 06:59 AM
akamob's Avatar
akamob
I got more or less the same problem, i got a 4x4 saph with a L6 in it and its running a bit lumpy, i did have a mates L8 in it and it was running fine
Old May 24, 2009 | 07:40 PM
saph cos rob
swindon rsoc
if your using a 4x4 loom with an l6 ecu and a 2wd tps you will need to swap the 2 outer wires over if they have not already been done
Rsmat
89
Oct 12, 2015 07:50 AM
Fil
Sep 30, 2015 12:08 PM
tib2220
Sep 14, 2015 12:33 PM
Tony W
Sep 9, 2015 12:08 PM
