Oil starvation
Right we think we may have found the issue that has coursed most of the damage, the new cam and lifters are fitted and the car was tried for a couple of seconds to find it tapping bad - after removing the rocker and turning over it appears that oil is being starved from the whole of the exhaust side - their is some but not enough to cover the tappings compared to the inlet side that completely covers them.
Any ideas why??? i know blockages could cause it but where do they normally get blocked as i don't know what the channels are designed like in a YB
No new gaskets lads - i haven't got a pressure gauge to check that but with it filling up fine on the inlet side i would say it appears that somewhere it's blocked - but where head or block?? what are the galleries like in the block compared to the head is there a difference in size??? the oil pump pumps one lot of oil thats then distributed between both sides??
I've just got some flush to see if that can help cure it but if not then the head will have to come off and sent for a complete clean - would prefer not too. I just need to know where the blockage is and why it blocked.
It's the whole of the outlet side so it must be further down than oil ways at the top off the head.
Could do with knowing the design of the galleries to identify where it splits into the individual channels
you jay have volume without pressure, check the actual pressure with a guage, if you havent got one, then buy one.
If this car has not had any engine work rcently sound like the galleries in the head are blocked assuming all else is good.
the yb heads have little grub screws in them to gain access to the oilway
try opening them and blowing them out a little with a compressor ,,may help without having to remove the whole lot
would personally take the cam out and the lifters before doing this though !!
grub screws are located on the front of head behind cam pulleys @ the corner of head
also on the side of the head @ the front corner of the head (will need to remove inlet manifold to do the inlet side)
there are also two on the rear but doubt you will be able to remove easily in situ
may be worth a try pal
try removing your cams and lifters and blowing it out with a compressor
may help free up any blockages out
worth a try before ripping head off
also two grub screws on the rear of head but not sure if they can be removed with head in situ
This is how it stands with the oil levels around the cams
So basically looking at the last image it feeds through the head via the inlet side and could be blown back through from the outlet side??? (blowing it from the outlet side)?
you do realise that its very common for the cams to snap on the YB, and it has nothing to do with oil starvation?
the colour of the oil is what would be on my mind mate, thats pretty bad for a 3k engine, it must be over fuelling perhaps?
Not in a petrol engine with only 3k miles on it mate, my competition engines have never seen oil that black and they are flat out when ever they are in use, you need to get this looked at.
just a blockage between inlet and outlet gallery across the front of the head, simple but caused loads of problems,
Markk i don't know what your trying to say but i have never seen oil stay gold, after 500 miles on the build it was black, after another 500 black again - oil goes black - if your still convinced this is wrong start a poll saying who has gold or black oil??
mate im really not that bothered to be honoust, glad its fixed for you. bit poor for a 3k build to have blockage though, im sure your happy though now.
deathrider666
Sep 28, 2015 06:12 PM
fixed
