any one used this (diagnostics)
after a setup any one had experience with this looks pretty comprehensive
http://cgi.ebay.co.uk/PANASONIC-TOUG...3A1%7C294%3A50
Note that it is a "USED" Laptop, with suspect battery, but the cost seems fair even for all the leads.
I've got an ELM interface and that came with most of the software shown , but only the basic leads, was only £30 tho'
looks like a laptop just loaded with load of software to me i would never choose something like that
go for a more dedicated machine, have a look at the snap on ones, not the solus there too dear but an older one
i use a mt2500 with a all makes cartridge, it also does eobd, seriosuly good bit of kit far better than laptop based ones, and a used one would be about the same money
i have just got the ethos kit off snap on it seems good but i wish i had looked around a bit more first lol as i only wanted it to reset the fooking landys suspension
. checky fooker wanted $500 for a reset after i fitted an ace pump so i bought my own kit
Mate bought one of these, not sure if it's the same guy but looks very similar. Tough book was very used and didn't have a drive in it plus it was just pirate software you can easily get from torrents, infact I had most already and some are useless. The copy of Carsoft wasn't even correct and I had to install mine on it. It does come with the cables, but you can pick them up for peanuts anyway.
Eli - I've heard massive horror stories about people using carsoft to change options in the system on BMW's only to find that the carsoft program has destroyed the firmware in the instrument cluster thus rendering the car a write off
Cheers Baz - I'll have a looksie around too
seriosuly look for an older snap on machione, loads and loads on ebay, dont want one with loads cartridges there older, you want an all makes cartridge, and can1b lead with a full set of keys, i keep meaning to sell mine and buy a solus, but finances are not excellent at the mo and i cant warrent the expence
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Damo V
Technical essay Archives
33
Jun 26, 2006 09:00 AM
Damo V
15
Dec 10, 2005 06:27 PM
