FAO all Cossie ECU/wiring loom gods.. Daz, Simon@SECS etc???
Right I am trying to get someone to plug their Diagnostic equipment onto my ABS. I still have the actual abs diagnostic plug by the battery
But because I have removed my old ECU/Engine loom and installed a Pectel item, I no longer have a plug which the computer needs... As a result when the diag equipment asks for IGN to be turned on/off etc, it doesnt respond....![Sad](https://passionford.com/forum/images/smilies/icon_sad.gif)
SOOooooo my thinking was to dummy fit the old diagnostics plug somehow, now this is my Q...
On the ECU (old loom) the following relates to the diag plug I need to "retro" fit...
Pin 8 - Electronic control loom (blue/white)
Pin 27 - Electronic control loom (blue/yellow)
Pin 11 - Map sensor (shielded) and link to common connection* (brown/green)
*Pin 11 (brown/green) connects to the following....
Coolant temp sensor
Throttle pot sensor
Aircharge temp sensor
Am I right to assume, pin 11 (brown with green trace) is some kind of switched earth?? i.e when the ecu is switched on via IGN it supplys an earth to the sensors listed above??
As I'm guessing this is how the diagnostic software/computer knows the IGN has been turned on/off??
pin 27 and 11... What happens there? are they simply diagnostics wires from the ECU and relate to the ECU only? they dont suppply an IGN live or anything do they??
Coolant temp sensor
Throttle pot sensor
Testing the future
what does the abs diagnostic equipment need? surely only a switched 12V power supply? if so, just connect direct to battery (via a small fuse).
but maybe it needs a 5v signal, as is used to supply MAP sensor etc?
Ive got a "datacheck" 100 and 200 thing they list the Teves system, do you know if they are compatible?
Why have 2 or three people refered to the ABS diag plug being by the battery? what is that for then?
Pin 11 is a common 5v reference supply to all the sensors IIRC.
I am not sure what the electronic control loom does to be 100% honest. It may be for code reading, octane adjust (although I think there is a seperate socket for this) or for resetting the ECU.
Ah right so its a 5 V supply, not an earth thanks Daz...
I reckon the electronic control loom is diagnostics for engine ecu as you say, there is another plug for "adjustments" with Black wires..
Now I am intruiged as to what the OTHER plug is for by the battery???![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
Its still there so isnt attatched to the engine ecu ??
Black wires on a Ford is usually an ignition feed?!
Oh
I was guessing it would either be as you say a switched live OR switched earth
hmmnnn thank you anyway
the other plug with black loom defo for ign adjust or summat
yeah it was // well it stil is attatched to the old loom which is sitting in hte shed in a black back ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
I might take some pics as I think Im confusing the issue
muz
30-09-2015 08:29 AM
Russ Payne
25-09-2015 08:29 PM
