Moving Phase Sensor to Cam Cover?
Old May 6, 2009 | 03:42 PM
Sonic Boom's Avatar
Sonic Boom
Default Moving Phase Sensor to Cam Cover?
Now i've converted to Wasted Spark I thought i'd go the whole hog and remove the dizzy completely. I've seen the phase sensor put in the cam cover on a couple of cars, but what do I need parts and machining wise?
Cheers Rich
Old May 6, 2009 | 05:37 PM
All the stuff you need you can get from Reyland, as you ned to keep the drive for the oil pump, so reyaland can supply a drive bit for this(think he needs your dizzy to machine for this), then I think most use a extension that goes on the rear of the inlet cam and machining to the rocker cover to take a sensor, to pick up the lobe on the extension.
Old May 6, 2009 | 09:02 PM
Sonic Boom's Avatar
Sonic Boom
Cool, Martoons only down the road i'll go and have a chat.
Cheers Rich
Old May 6, 2009 | 09:42 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Look at this thread
https://passionford.com/forum/techni...r-to-a-yb.html
BRAMMER
15
Sep 14, 2015 08:52 PM
Chopshop85
Sep 12, 2015 06:42 PM
Si B
Sep 12, 2015 06:49 AM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
rog
Sep 4, 2015 07:24 AM
