timing marks on ford focus 1.6
Old May 4, 2009 | 01:18 PM
fiestamk2's Avatar
fiestamk2
Default timing marks on ford focus 1.6
hi im after fitting a new crankshaft oil seal to the 1.6 zetec se engine.has anyone ever done one?or no the timing marks.has anyone ever fitted a new timing belt and can share there experiences.
Old May 6, 2009 | 08:33 PM
mercury grey minter's Avatar
mercury grey minter
You will need a timing kit.Consists of crankshaft pin and camshaft locking bar as there is no woodruff key on the crank and no timing marks.
You need to insert a pin into the bottom of the block and turn the engine until the crakshaft hits the pin,then lock the cams off with a bar,then you have got tdc.
Old May 7, 2009 | 07:12 PM
ob1marty's Avatar
ob1marty
as my man said but watch it as the crank and cams have no woodruff keys so need to make sure pulleys tight b4 turning over
Old May 8, 2009 | 10:15 PM
fiestamk2's Avatar
fiestamk2
thanks for ur help
taylora1409
Aug 12, 2015 12:06 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
