Wheel size....will they fit??
Seen a set of wheels i quite fancy but un-sure if they would fit an RS Turbo or not. Would be going on a F plate Escort RS. Suspension dropped on Koni Adjustable Shocks and 25mm Springs.
Wheel size: 8x17" ET35 4x108 PCD.
cheers in advance.
cheers in advance.
In what areas will they rub mate?? Is it possible to have the area's modified to eliminate this? Or would it be more adviseable to just go for more narrow wheel??
cheers
cheers
Also, large/wide wheels/tyres on the front of a front-wheel-drive car, will feel nasty to drive with on the road.
I'd run 7" wide maximum, mine are 16" diameter, which I consider optimum. 195/45/16 is a nice size road tyre, I run 205/45/16 for gearing.
borboyous
Aug 22, 2015 11:17 AM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
