fiesta door help
oki is there an easy way to get the pins out of the mk3 fiestas door cos ive been tryin 4 ages and they seem to b not moving at all, i dont know if theres a trick to it or any thing.
thanks rich
thanks rich
are you havin a problem with not being able to unlock the door unless you get in from pas side and bounce the door wilst pulling the interior door handle if so im havin the same problem and it seems impossible to repair without new locks
Basically there isn't any easy way
The pins will either come out straight away or they rust thereselves on and need some heat to move them, you really need to take them to a bodyshop thats done them before.
Oh, and when you order new pins up they are the same as mk4 ones, if you ask for mk3 ones from Ford they won't be able to get them
this place will supply you with new ones, around Ł12 delivered for a set of 4 and retaining clips
www.fordpartsuk.com
and fill out the parts request form, mine took around 2 days to arrive
www.fordpartsuk.com
Can you not buy a tool for removing the pins ? The last time I had this problem was with a mk2 GTE.I made a bar like a ruler with a slot cut out at the end,big hammer job done.My 10p worth
but as I say I've seen these fall out and I've seen 2 blokes struggle for over half an hour to get one out.
They can be a pain especially when they have snapped and rusted in
Erm yes I dont think as it was as easy as I earlier posted,my memory is hazy of that day,lol, and I think one of the pins on one of the doors did give jip
The bar worked a treat though
ha ha.
As said its a pig of a job to do as they get stuck in, easiest way is bang it up as far as u can so you can get to the head of it, then as said either get the right tool or grind the middle out of a thin-ish bar so it slides under the head and bang it out that way, thats how i had to do it!!! unfortunatly u cant really get anything like a pin punch to push it thru from underneath, well from memory anyway was about 5yrs ago when i did it
they can be night mare have known them to break the proper removing tools.
but as stated the only real way is to beat them out unless you are replacing the door then you can cut the hinge on the door side of the pins.
oki ill try again 2moz ill try heatin the metal up first c if it moves if not i might just cut the hinge off seen as im replacing the door thanks 4 your help
Adam Graham
Sep 6, 2015 06:04 AM
