Overfuelling/running rough
Old Feb 22, 2004 | 09:37 PM
Dave McB's Avatar
Dave McB
Default Overfuelling/running rough
First thing in the morning (as faras i can remember in the cold) my cossie coughs and splutters a helluva lot. there is a smell of petrol and the plugs are sooty.
I know sooty plugs=overfuelling, but could this be anything to do with cold start problems??
The car runs light green injectors and god knows whatelse.
How can this issue be resolved, cos its gettin on me nerves. Will i be better gettin it set up properly, or is there somethin else worth trying first?
Old Feb 22, 2004 | 10:45 PM
Toe Knee's Avatar
Toe Knee
Nah mate sounds like it needs setting up, mines similar, plugs are black and overfueling like a bitch!!!
Old Feb 22, 2004 | 11:07 PM
PJay's Avatar
PJay
Does it only so it when cold? if so check the iscv
Old Feb 22, 2004 | 11:38 PM
Toe Knee's Avatar
Toe Knee
Ah didnt read it does it in the morning yea could be ISCV then, do you have the same problem once its warmed up and ur givin it a bit of stick?! ie overfueling
Old Feb 23, 2004 | 06:29 PM
Dave McB's Avatar
Dave McB
yeah it seems ok after a coupla minutes. no noticable coughing and spluttering after about 5 mins.
Where is the ISCV and what does it lookie like? how do im sort that? in the vauxhalls all u needed was some spanners and WD40. same idea on a cos?
Old Feb 23, 2004 | 07:07 PM
Toe Knee's Avatar
Toe Knee
On top of the throttle body theres a white cylinder thing with aplug on it, sometimes they stick of fook up so yea take it off and have a look if its sticking or not!
Old Feb 23, 2004 | 07:39 PM
HI,
TRY COOLANT TEMP SENSOR, SENSOR FOR ECU ENGINE TEMP, NOT SENSOR FOR (TEMPERATURE GAUGE ON DASH,, ALSO IF YOU HAVE THE KIT CHECK CO% AND FUEL PRESSURE, ALSO THAT YOU HAVE A STRONG SPARK AT PLUG'S,
Dave,
Old Feb 23, 2004 | 11:31 PM
PJay's Avatar
PJay
Easy way to check ISCV for operation is to unplug it why the engine is running cold and see what happens
If you need a new one i've got 2
Old Feb 29, 2004 | 11:02 AM
Dave McB's Avatar
Dave McB
cleaned the ICV with carb cleaner (actually, i sprayed it with spray glue first by accident.....cans are really similar ) and it idles much better!! (still overfuelling tho, not as bad)
cheers for the help guys
TPM961
Jan 15, 2018 10:50 AM
pabloXR
Sep 21, 2015 12:42 PM
Brickhouse
Sep 21, 2015 11:00 AM
jonnyenglish
Sep 21, 2015 07:31 AM
