Finis codes for inlet & exhaust stud&nuts for rst
Hi
I´m looking for buy brand new set of INLET MANIFOLD AND EXHAUST MANIFOLD STUDS & NUTS for my Escort RSt S2 Head.
Anyone know Finis codes or where to buy online??
I did use the search but I didn´t find the info.
Many thanks
Many thanks
I can help with the exhaust side, but not the inlets.
Exhaust Stud - 1024339
Exhaust Washer - 1465430
Exhaust Nut - 6134209
Exhaust Manifold Gasket (incase you need it) - 1023231
Hello Anvini good to see more people from Spain. I changed recently studs and nuts in my CVH and studs are the same in the inlet and in the exhaust. Also the nuts are the same , the only difference is the washer.
However, on the inlet side, don't forget that there is a tube nut arrangement and a short stud in the middle too.
Thanks for the response christian! I recently changed all the studs in my head and I used in inlet and exhaust the same type and all is fine. Also I am talking about the naturally aspired CVH, and I suppose the turbos may be different.
In my car originally studs in inlet and exhaust were the same and they don`t have the torx head for inserting the stud
good to talk with spanish people here in Passionford...........
I see that you live in Malaga, I´m from Elda (Alicante).
Where did you buy the studs and nuts??
So I can use exhaust studs and nuts for inlet manifold too??????????
Saludos paisano..................
I bought the studs and nuts in my ford dealer. No problem because that studs are used bu later editions of the cvh so they keep them in stock. They are not cheap at 2€ each but at least the quality seems to be very good , and the torx head makes them easier to insert the stud.
Un saludo para ti tambien!
Gracias por la ayuda.
JK12
33
Apr 26, 2021 12:09 PM
