big problems with my rs engine
Old Feb 21, 2009 | 05:27 PM
RSTurboSI's Avatar
RSTurboSI
Default big problems with my rs engine
MFI engine setup.
whats going on is, the head gaskit went, been replaced and went again, new ford gen gaskit and new balts, ect...
but been taken out and again headgaskit has gone, pooring white smoke and poping off the oil cap,
the engine has only done 6,000miles since rebuild. what could be my problem?
Old Feb 21, 2009 | 05:31 PM
boost monster's Avatar
boost monster
I think your head could be warped, was it checked?
RSTurboSI's Avatar
RSTurboSI
oh it keeps spliting the head gaskit at number 3 cylinder, running 11psi.. just been up for a setup and he remove the vacum hose which goes into the ecu
Old Feb 21, 2009 | 05:32 PM
RSTurboSI's Avatar
RSTurboSI
sorry yes been skimed and pressure tested.
studabear's Avatar
studabear
have you had the head pressure tested and skimmed?
Old Feb 21, 2009 | 05:33 PM
RSTurboSI's Avatar
RSTurboSI
as above your post
Old Feb 21, 2009 | 05:37 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
Originally Posted by RSTurboSI
as above your post
block decked??
Old Feb 21, 2009 | 05:39 PM
RSTurboSI's Avatar
RSTurboSI
nope not looked at the block, looked fine when removed the head
Old Feb 22, 2009 | 11:10 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Where was it setup? If it keeps blowing HG's even with a freshly refaced head then it running too hot and/or detonating.
Old Feb 22, 2009 | 01:02 PM
RSTurboSI's Avatar
RSTurboSI
setup in at basford dyno tune, aparntly all he has done is blanked off the vacum hose from the ecu to the MFI inlet. and its running 11psi.
when the head gaskit goes the oil cap pops off, seams like the bottem end has gone?? but there is no mayo in the dipsitck at all, and the bore of number 3 to where its poping the gaskit is smoth, no lines or scores.
its a good bottem and only been rebuilt 6000miles ago
Old Feb 22, 2009 | 01:13 PM
Karlos G's Avatar
Karlos G
Balls Deep!
WTF? If the Vacuum pipe to the ECU is blocked off then your timing will not be adjusted as the boost pressure increases and this is why your popping HG's!! Lucky you have not holed a piston yet! Although with the Oil cap popping of i'd say you've fried some rings.
Why did he do that??
Old Feb 22, 2009 | 01:47 PM
stevedb's Avatar
stevedb
I had a hairline crack in my 1st block you could hardly see it but it blew two head gaskets one after another. Got a new block and its been fine ever since.
Old Feb 22, 2009 | 02:46 PM
RSTurboSI's Avatar
RSTurboSI
thats what i was thinking, clown is what i can say, hireline is poss, the garage its in now is ganna get looking at it again, looks like a new botten end,
where did u get your bottem end from? steve
Old Feb 22, 2009 | 02:49 PM
RSTurboSI's Avatar
RSTurboSI
all the mayo is at the top half of the engine, there is no mayo in the sump, would this tell me my bottem end is safe bar my pistons
Old Feb 22, 2009 | 05:04 PM
kidsRS's Avatar
kidsRS
"Ill check the stock"
What a bunch of pricks taking that hose off!
Old Feb 22, 2009 | 05:09 PM
boothy's Avatar
boothy
get them cunts to foot the bill, piss taking bastards....
Old Feb 22, 2009 | 08:21 PM
RSTurboSI's Avatar
RSTurboSI
the cunt wont take any Responsbilty, at all.
You know what made me laugh aswell, the guy whos doing my work a garage near my office went and spoken to him to find out just what he has done.
from what he said was just removed the vacum from the ECU, i thought it was a bit strange myself but he said that was the problem,
he also said there was no way of ajusting the boost, ermmmm there is, its called a Acucrator(sp) Rod that you turn!..
im going to take a look into my options for the billing to be at his exspence, the engines only done 6,000miles not even that.
he sounded like he knew his fords and told me hes delt with a few before, the guy doing my work is pritty clue'd up... fucking 2half k engine GONE by some cunt who thinks he can tune a RST!!!
Old Feb 22, 2009 | 10:02 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Thats pretty bad mate! I'd be going mental at them and trying to get some sort of compensation...... really is a piss take!
Old Feb 23, 2009 | 01:56 AM
stevedb's Avatar
stevedb
I bought the whole engine off a lad on here who was breakin a fiesta turbo.
Old Feb 23, 2009 | 02:06 AM
Rs Baz's Avatar
Rs Baz
have a good engine or block if you need one
Old Feb 23, 2009 | 02:36 PM
PaulT's Avatar
PaulT
Basford Dyno tune been there myself but would not go again same with Geoff Bloors in Bridgeford melted my wiring loom. Take it up to Nobles in Chesterfield had no problems here.
Cheers PaulT
Old Feb 23, 2009 | 02:46 PM
boothy's Avatar
boothy
hope you sort it mate, alot of money down he drain....
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
track.focus'd
Aug 12, 2015 05:53 PM
Blown Hell
Aug 5, 2015 07:22 AM
