Any one willing to give some tips on filling.
Old Nov 27, 2004 | 10:27 PM
L33 BYT's Avatar
L33 BYT
Default Any one willing to give some tips on filling.
I just cant seem to get it to match the contour of its surrounding area.
Old Nov 28, 2004 | 09:16 AM
fomoco90's Avatar
fomoco90
Default ;
hmm interesting but what surroundings are we talking about, have some experience with filling, just look at me project, "here we go.."
Old Nov 28, 2004 | 10:27 AM
luke89's Avatar
luke89
Team HOTHOT!
i have done some filling well me and my bro smoothed front and bak bumper. always fill it higher than you need to and use a flat sanding block with ruff paper to start . thats the only tip i can give you. hope it helps
Old Nov 28, 2004 | 03:39 PM
L33 BYT's Avatar
L33 BYT
Just re read my posting.
Old Nov 28, 2004 | 03:44 PM
fomoco90's Avatar
fomoco90
RST_lee, soz m8, no clues except "contours", "surroundings", try and solve the riddle
or it might me being slow at English or to dumb in catching the clue soz
Old Nov 28, 2004 | 03:55 PM
L33 BYT's Avatar
L33 BYT
Actually all my fault. Being perverse and mis read your post.
Just looking at your thread now. Apologies. English is fine it was me
Old Nov 28, 2004 | 04:09 PM
fomoco90's Avatar
fomoco90
RST_lee, thx Ben
Old Nov 28, 2004 | 08:29 PM
escort1989uk's Avatar
escort1989uk
the haynes manual has a quick easy and details pic process of filling a dent or bridging a hole
Old Nov 28, 2004 | 09:40 PM
Piinko-RS's Avatar
Piinko-RS
get ya self a good rubbing down block and its a case of trial and error mate ,fill rub refill rub more etc
good tip is to spray over the repair with a different colour , then rub down if ya need more filler in the different colour paint will be left in dents etc repeat rinse and u should have it some where near sorted.
Old Nov 28, 2004 | 10:38 PM
escort1989uk
this is called spotting when you spray the filler with paint as it shows the high and low parts of the filler but once you have think you have finshed filling your repair there is another product which is like a putty and it fills up the little pinholes that your eyes won't really pick up
Old Nov 29, 2004 | 05:20 PM
black LS's Avatar
black LS
if your fillering onto metal then make sure you scratch the surface up with some ruff sandpaper, it'l help the filler stick and make it easyer to feather the edges out. And buy some bigger spreaders, use the small one you get with the filler to mix it, then use the bigger ones to spread it, that way you don't get filler all over the spreader and your hands
Old Dec 2, 2004 | 06:17 PM
L33 BYT's Avatar
L33 BYT
Cheers guys.
Old May 28, 2005 | 08:22 AM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Anyone know what this product is ?
Old May 28, 2005 | 10:53 PM
Boris357's Avatar
Boris357
Haynes call it stopper paste
Old May 28, 2005 | 11:00 PM
Moose 130's Avatar
Moose 130
Personal preferance, but I like Plastic Padding rather than anything else.
My old man used it exclusivly in his bodyshop even though it was dear, best stuff he recons.
Always remove the paint from the fillered areas or you'll get a 'shadow' in the paint.
Filler should be used to finish the surface, not build it up.
Put several thin skims on, rather than one thick one.
Once filled, we used to brush paint primer onto the filled areas to get a high build, then wet flat it off, found it filled any scratches well. Then primed over the top again with the spray.
Old May 29, 2005 | 09:01 AM
frog's Avatar
frog
Craig,
where do you get this plastic padding from ?
Old Jun 1, 2005 | 03:37 PM
Ginge !'s Avatar
Ginge !
just finding my feet
Craig,
its also called celulose putty or ya can buy filler primer too thats yellowy
Old Jun 1, 2005 | 05:38 PM
muz's Avatar
muz
Wye Valley Hardcore
you can also get some regular filler and "water" it down using mineral spirits to get a thin paste to fill thes tiny holes. it sets just as hard as filler.
Old Jun 1, 2005 | 06:18 PM
ProjectBobcat's Avatar
ProjectBobcat
personally i swear by UPOL easy sand filler and the stuff you want for filling really tiny holes, pin pricks etc is Holts cataloy knifing putty. Its available from halfords in a small tube for about 4 quid.
Old Jun 2, 2005 | 12:01 AM
Snowy_Astra's Avatar
Snowy_Astra
Dunno if its been said, but always use more filler than you need. For instance if you got a dink in a panel that is about 1/2 an inch wide, then fill 4-5 inches around it and blend it in, that way you get a nice finish and don't have to fuck about too much.
tankybaby66
Feb 6, 2016 02:24 PM
Mc5506
Oct 5, 2015 09:57 PM
SMILER258
Sep 28, 2015 09:04 AM
