Stage1 270bhp proceedure
Old Feb 2, 2009 | 07:31 AM
ianbobo's Avatar
ianbobo
oohmamama
Question Stage1 270bhp proceedure
Hi friends
I've got a saph 4x4 factory standard engine and turbo, samco air and water hoses, factory air box with K&N filter + 2 bar map sensor + mongoose exhaust + Koni sports suspension all round.
How do I go SAFELY for stage 1 (is it 270 bhp? ) ?
Is it possible to do it myself?
Thanks guys.
Old Feb 2, 2009 | 07:41 AM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
give stu @ msd a ring (he's admin on here)....he will post out everything u need
Old Feb 2, 2009 | 07:45 AM
All you need for stage1 is a chip, and a -31 actuator for the turbo, very easy to set up with instructions provided.
I have never used a MSD stage 1 chip so can't comment, but have used GGR, about twice the price, all I can say is it was awsome, brings a shed load more torque, that's the first thing you notice, much much better, and what they should have been to start with imo.
You won't go wrong with either of the above though, or Karl at NMS, does the special high popwer chips, can't remember the name but very effective they are, Gunship, just remembered.
Old Feb 2, 2009 | 08:02 AM
Twellsie's Avatar
Twellsie
Karls Gunship conversions are awesome
Old Feb 2, 2009 | 09:48 AM
Mathias's Avatar
Mathias
If your car has catalysts, you should remove the one in the downpipe and order a
closed loop chip.
Old Feb 2, 2009 | 03:52 PM
ianbobo's Avatar
ianbobo
oohmamama
Thanks for your replies guys..
What about my ECU... would I just plug in the stage 1 chip or would I need to solder?
Does my ECU has something called pectel board? I need some updating in this matter.
What about the cooling system? will it cope with the extra heat from the extra power?
Thanks again
Old Feb 2, 2009 | 04:15 PM
mechanic28's Avatar
mechanic28
plug and play mate!cooling system will handle stage 1 with out any problems!
Old Feb 2, 2009 | 05:34 PM
If the cooling system is in good order it will cope no problem as it's 4wd, 2wd were pretty crap from the factory, but 4wd have much designed systems.
Tangodeltasierra3
111
Jul 12, 2006 12:37 PM
cozzie4d
Apr 15, 2006 08:34 PM
Cossy Chris
Nov 26, 2005 05:35 PM
Alps Pacino
Feb 9, 2005 06:51 PM
DOO
Sep 20, 2004 07:54 PM
