boost problem??
Old Jan 1, 2009 | 05:46 PM
mikemcc03's Avatar
mikemcc03
Default boost problem??
hi my head gasket give up monday night so stripped it tuesday an found the head was knackered luckily i had a ford gasket an another good head so swapped everything over fitted all back together no probs only thing now when coming onto boost as i comes in its as if its over boosting an popping but was running more boost before gasket went with out this problem i closed the bleed valve before takin car on the road.
could this be a simple problem of needing a good set of plugs an leads? i know the car needed setting up anyway before gasket went (luck it went now an not on rollers) but i would like to eliminate it before i go on rollers car is still driveable just not really boostable. any suggestion welcome thanks.
Old Jan 1, 2009 | 06:09 PM
adam.d's Avatar
adam.d
Was the head you took off ported/polished? and the 1 you refitted standard?
Old Jan 1, 2009 | 06:35 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Did you refit the dizzy in axactly the same place? If not timing will be wrong.
Old Jan 1, 2009 | 07:30 PM
adam.d's Avatar
adam.d
Good thinking!
There is some marks on the dizzy and head to align
Old Jan 1, 2009 | 08:24 PM
mikemcc03's Avatar
mikemcc03
i dont know about the port an polish tbh... dnt think so the head looked like it had been skimmed a few times too many tho
ive had to move the dizzy to get it to run tidy enough to drive because when i first started it, it run like a pig so tryed movin dizzy then re-checked the timing marks (spot on standard marks) also i broke my T peice to the boost gauge so cant tell wat its boostin till i get a new one tomorrow im going to check the emissions an maybe turn the boost down on the actuator as it seems to be tryin to boost more than before.
a thought do you think it could be blowin the spark out once boost pressure gets to high?
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
