Problems with s2.
Old Dec 28, 2008 | 08:59 PM
Dex-Man's Avatar
Dex-Man
Default Problems with s2.
Woke up this morning and the rs wouldnt start so i bump started it thinking the battery was dead and then drove it around for an hour or so thinking this would recharge the battery, i tried to start it up once i got home and its just clicking now, everything works ie lights hazards cd player, iv tried hitting the startor motor and nothing has happened. anyone have any ideas thanks in advance.
Old Dec 28, 2008 | 10:30 PM
orionmojo's Avatar
orionmojo
the battery is completly fooked mate. thats all.
a new one should sort it out
Old Dec 28, 2008 | 10:43 PM
tasos77's Avatar
tasos77
rs turbo from Greece...
Or your altenator isn't charging the battery any more...
Old Dec 29, 2008 | 10:31 AM
orionmojo's Avatar
orionmojo
but if it wasn't charging when it was running it'd stall when at idle i'd have thought, i stand to be corrected though
Old Dec 29, 2008 | 10:43 AM
D16PJM's Avatar
D16PJM
if your alternator wasnt charging the car would not of run for a hour with a flat battery, id say starter or battery, have you tried putting a volt meter on the battery with it running to see what power is there, should be between 12 and 14 if i remember and then check when you turn it off.
Old Dec 30, 2008 | 10:06 PM
johnnysash's Avatar
johnnysash
ditto. but should be anything above 12.5 if your alternator is in good nick... also try the same test with all your electric stuff turned on (full beam, heater, heated screen, blower wipers etc) see how much the the voltage drops (you could have a shite wire from the starter motor to the alternator causing volt drop!)
having said all this from what you describe I am guessing starter is fooked!
Old Dec 31, 2008 | 10:48 AM
ricky_2006's Avatar
ricky_2006
batteries get fucked overnite sumtimes. just the way it is. once battery is knackered then thats it.
get a new one mate. i got like 640a battery from euro car parts, just fits in
Old Jan 2, 2009 | 04:33 PM
TrevCos's Avatar
TrevCos
One thing to check as well is that your boot light isn't on all the time. The switches are temperamental and if it is this drains off the battery without you knowing. Just pull the back seats forward and check without opening the boot lid. If it is just pull the bulb out. This has happened to me on several Mk4s now. You might need another battery as well but it'll stop it happening again if it is the case.
Old Jan 2, 2009 | 05:01 PM
Smartdj.'s Avatar
Smartdj.
if everything else is working and bttery has power then its ya starter motor m8
Old Jan 2, 2009 | 07:44 PM
rsfido_1989's Avatar
rsfido_1989
had exactly the same problem.. new starter fixed it.
good luck bud
Old Jan 3, 2009 | 09:00 PM
studabear's Avatar
studabear
I would be wanting a minimum of 13.4 volts even under load , an off the shelf battery should have 12.6 volts, 2.1 per cell
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
