pistons with valve cut outs
does any know the the measurements to put valve cut outs in mahle pistons for cosworth engine?
size of cut outs?
how deep?
the angle of them?
and anything else i will need.
size of cut outs?
how deep?
the angle of them?
If you take them to any good engine place they should be able to do the work if you give them the specs. They normally are at the same angle as the valves and the same diameter, the depth is dependant on cam selection, you need to have a minumum piston to valve clearance of around 1mm (40thou) when fully open to be safe on engine where the valve are vertical so you will need a greater clearance due to the valves being angled
