Impreza sti vs St170
Dont know whats got into me but keep liking the look of the impreza's lately (classic shape)
currently got an st170 that the misses uses but now with 2 kids and only 3 doors do I look for a 4 door(enter the impreza!!)?
How do they fair day to day driving? I've caged a couple but never actually been out in one for a go.
i'm not fussed about having 400hp etc as I got my lightning for horsepower...
Had an ST170 as my daily driver up until about 6 weeks ago, I'd probably go with an Impreza tbh. Can't fault the Focus I liked it MUCH more than I thought, just never got on board with 6 long gears on a revvy engine, never pinned you back.
It was reliable too, only had to replace downpipe & cat in just under 9 months. Was an '04 plate.
If you can justify a little hike on running costs Impreza all day IMO.
I've had my Focus for about 15months and its never let me down apart from drivers side window not working(motor jammed). I know what you mean about the long gears and to drive slow they feel guttless (is this a good thing for the misses) but once they are wound up I really enjoy even on greasy roads I find it impressive.
The Impreza is really very civilised and comfortable as a daily driver. The classic shape interiors etc may not look the best, but they're very well screwed together and hard-wearing.
Aside from that I've always found them pretty refined, far more so than an Evo for daily driving. The Evo always feels like it wants to go fast, the Impreza not so much so.
If it's definitely an STi you want then they'll be plenty quick enough as standard.
I'd go for a V5 as the best all-rounder in terms of performance/spec/price/refinement etc
Out of curiosity, whats the fuel consumption on a normal day to day basis? (of the impreza i mean?)
Plus are the uk classic models "super plus unleaded" only or can you run them on supermarket unleaded?
Classic shape WRX's had 220-240-BHP (ish) as standard, STi's had around 280
STi's were manual-only, had forged-pistons, uprated intercooler with water spray, special ECU, special exhaust, special diff, strut brace, larger STi spoiler, better seats, uprated brakes etc.
Not local to you, but just as an example, that's the model I'd go for
http://search.autotrader.co.uk/es-uk...0&max_mileage=
There were a few worthwhile tweaks to the V5 making it a good improvement to the others. There wasn't any significant changes to the 6 to make it worth choosing over the 5
I'd rather keep the 3dr to be honest if owning a focus, I dont see it as a big deal for my 2yr old, its just a paint strapping the little baby seat in the back, If the pass airbag could be switched off he'd go in the front and there wouldn't be a prob. also I quite fancy a subaru but will have a drive of a couple first.
That place always has lots of really good Jap Import cars in, and usually at a good price for a delear.
All decent STi 5's should be somewhere in the £5-7k price bracket really
Shouldn't be anything really to worry about with the later STi models.
Earlier models often suffered with headgasket problems, and pistons were weak on normal WRX's, but STi ran forged items.
Only thing likely to cause major engine problems in later STi's (V3 onwards) would be using 95RON fuel, which these engines really didn't like
Some MY98 cars had replacement engines through a recall after suffering from piston slap
but by now, all worries should be over for these cars, just use 97RON fuel
I've had both and would go for sti everytime,on a run maybe 28ish mpg around town about 17/18ish mpg. Rag it and you won't see much more than 8/10 mpg.
Had mine down to 8mpg going down castle comb one year.
Normal stuff service history,no managment light on,cambelt done,more standard the better.
Get in one rev to about 4000rpm dump the clutch and smile.
Found a V4 30miles from me with 75k on the clock, if there next week might go for a look as away this weekend. best clean the focus and say my good byes lol!! actually best see what a 3 owner 3dr 02 ST170 is selling for...
Whats the differents between the versions Mike? I seen loads of V4 withing 40miles from me but no V5.
Without trying to cause offence... you dont really seem to know much about these cars, so please stay clear of Keighley Trade Centre. I'm sure if you were to google them, you would see why I'd say that, there are MANY horror stories about them... and actually about a few garages in that general area.
Pictures and prices look good... and I have heard of a couple of decent cars to come from there, if you know what you're looking for and give each car a proper inspection then you can walk out with a bargain. However, its a big gamble to take.
The main reason for engine failure on earlier Imprezas (pre-97) is the tiny top mount intercooler and poor scoop design... prelonged 100mph+ runs mean that it runs very lean and after a while, results in a knackered engine.
The later phase 1.5 and phase 2 engines are better designed and have a larger capacity top mount fitted. But the engine failures on these tend to be from people thinking that they can get away with running it on super UL (or worse, normal UL) only when the car is designed to run on the japanese 101ron rated fuel. Same as most P1's you'll see have had a rebuild as they are basically just a Version 5 STi with the standard STi ECU and an in-tank fuel broquette fitted from new.. which will have dissolved by now causing the car to detonate on super UL unless its been re-mapped for UK fuel.
Cheers,
Grant
Cheers,
Grant
Aside from that, slightly tweaked suspension and the newer style spoiler and bodykit and I think that's about it
Cheers,
Grant
Cheers,
Grant
Everyone I know who's ever had a P1 have had to have a complete rebuild, lol.
Version 4 requires a complete new ECU (PowerFC, Simtek etc) to be mapped for UK fuel... looking at about 800quid+ for that to be supplied, fitted and mapped.
Version 5/6 can have the standard ECU mapped using EcuTek software, which is about 500quid to buy the licence and be mapped.
Front bumper, headlights, grill, rear spoiler are different between the models on the outside. Interior is practically identical, there's a slightly different MOMO badge on the steering wheel and the gear gaitor is leather in the Version 5 intead of rubber on the earlier model.
Cheers,
Grant
Cheers,
Grant
A friend bought a Supra from Keighley Trade Centre and that was spot on. Never been in person though, have just noticed when trawling the ads that they always have a large selection of Jap imports that look good.
I've also read on a subaru owners club, from another well respected importer, that the new/delivery mileage stuff they get hold of is good quality too.
Cheers,
Grant
Cheers guys,
Trust me when I buy a car it is inspected very well hence asking questions before hand and not after i got one. You've gave me some very good info though and thank you for that, Like I spotted the recon engines I knew there must be some reason which from what you have wrote makes very good sense. I Mite pop up and see ZEN performance as they just up the road from us.
Don't discount a late (year 2000) classic UK or euro Turbo..
Firstly I'd decide what power/performance you're after and go from there.
I've had most of the classic models and the one I've had the longest has been a UK spec turbo. I have just modified mine with a VF35 from a 2003 STI, power FC, walbro and just had it mapped Monday by Simon aka jollygreenmonster and it really shifts now. I'd estimate 320bhp (going by previous cars I've owned) with probably not far off that in torque.
My favourite engines on the Imprezas are either the version 2 engines (95-96) or the version 5/6 UK engines (99/00) The 97/98 just don't feel great to me and usually sound slappy from cold. I currently also have a version 2 STI RA with the CDB and it feels like granite, it sounds perfect from cold and feels strong.
I've read lots over the years and owned many STI's and IMO the classic STI engines (apart from pre 96) don't seem all that great to me.
Most people will reccomned an STI of some sort because it's got better suspension, more power etc but my advice would be to look for a decent low mileage year 2000 UK or euro 2000 Turbo with some choice mods. Most of them have things like suspension changed etc anyway. You can do ecutek remaps on the v5/6 cars too and an exhaust, filter and remap will get you 260/270bhp and similar torque or (like I have) add a VF35 (cost me £200) which fits straight on with no mods in the mix and you're looking at 320bhp.. stock injectors on v5/6 cars are 440cc and these and the stock v5/6 intercooler will see you to almost 350bhp without being changed.
Thanks james, you mean something like this
http://cgi.ebay.co.uk/Subaru-Impreza...1%7C240%3A1318
or
sorry forgot how to do nice link!
or
holy sh.. the 1st one is exactly what I was looking for, thanks
I wanted a sonic blue euro turbo! I have a sonic blue wagon and it's really rare on a classic (sti's are common in sonic)
Wish this was about a couple of weeks ago.. hmm.. spose I could swap my bits
I wanted a sonic blue euro turbo! I have a sonic blue wagon and it's really rare on a classic (sti's are common in sonic)Wish this was about a couple of weeks ago.. hmm.. spose I could swap my bits
I've cracked off an email so back off LOL
if that's genuinely that mileage and hasn't been repainted anywhere.. I want it
I'd highly reccomend it to you though, a rare car in that colour and mileage.. and as I say a few easy mods and it'll be a rocket and still feck all to insure (£400 FC for me n the mrs)
if that's genuinely that mileage and hasn't been repainted anywhere.. I want it I'd highly reccomend it to you though, a rare car in that colour and mileage.. and as I say a few easy mods and it'll be a rocket and still feck all to insure (£400 FC for me n the mrs)
Andypandy260
Sep 23, 2015 10:28 PM
