left turn cossie issue
Old Nov 23, 2008 | 01:38 PM
m4ttyrs's Avatar
m4ttyrs
Default left turn cossie issue
Can anyone help me with this very strange problem thats occuring on my escos? First of all the car starts, runs & goes fine. The problem occurs when i go round a left hand corner, the car just dies for a few seconds & then springs back into life as if nothings happend & its only left handers when it happens. I know this sounds strange but ive been out in the car for an hour today & it is definatly only left hand corners that cause the problem, the only time it doesnt do it is if i crawl round the corner at like 5mph. Any help would be appreciated thanks.
Old Nov 23, 2008 | 01:41 PM
Kverna's Avatar
Kverna
Virgin-popper
How much gas do you have on it ? Water inteferring with something when the gravity pulls it to the right ?
Old Nov 23, 2008 | 02:05 PM
big mac's Avatar
big mac
fuel or fault coil possible mate does it back fire when it comes back to life??
Old Nov 23, 2008 | 02:58 PM
ECU Monitor Enthusiast
Start up the engine, and start shaking bits of the loom to see if it dies.
Also, look at the fuse box (try moving that too) as that is a common problem on escos's
Old Nov 23, 2008 | 03:03 PM
m4ttyrs's Avatar
m4ttyrs
doesnt matter whether your foot is flat to the floor of no throttle at all, changed the coil back to the standard one and it still happens. The cap was left off the header tank and some water spilt into the engine bay, if water has got in somewhere what should be the first things i should check?
Old Nov 23, 2008 | 03:11 PM
LHD220Turbo's Avatar
LHD220Turbo
just drive in a straight line mate
electrical problem will be my guess; check the simple things first, cps would be a good place to start; then as flux says; start on the loom
Old Nov 23, 2008 | 04:11 PM
Xteam's Avatar
Xteam
fuelpump? a xr4i had the same problem, fuelpump was the problem there..
Old Nov 24, 2008 | 03:50 PM
m4ttyrs's Avatar
m4ttyrs
Im guna go with the fuelpump idea i think, spent all day yesterday checking all electrical things & found nothing. thanks guys.
Old Nov 24, 2008 | 04:28 PM
cozzymatt's Avatar
cozzymatt
has it still got the multiplugs on the N/S inner wing as these are just in front of the header tank! fuck them off if they are still there and solder them together!
Old Nov 24, 2008 | 04:51 PM
Examine the condition of fuse 5 in the fuse box !!
It is a VERY common problem for this or the internal connections of the box to fail.
I had this on both my escos's.
You may need to bang it a bit to replicate the fault when standing still. !
Old Nov 24, 2008 | 05:23 PM
PAUL S's Avatar
PAUL S
check your rubber engine and gearbox mountings, especially as yours is a 4x4 its a well known failure point, usually drivers side next to the turbo -it could well be one is shot and in left hand corners your engine could actually be moving and putting a strain on part of the engine loom if its tight or held in place with a tie strap etc and causing a momentary disconnection then when your straight again the strain is reduced and the cable goes back into place
Old Nov 24, 2008 | 07:25 PM
m4ttyrs's Avatar
m4ttyrs
Been messing with the car again. Nothing wrong with the fuse box i have had it out in my hand and moved every single wire, checked number 5 fuse & thats fine. I have moved every connection under the bonnet whilst the car was running but nothing. I have just been out in it again and it only cuts out when i go round a big left hand corner. I could swerve the car side to side & nothing would happen. I could also go round a small left hand bend & its fine. It just seems to be any big left hand bend.
Old Nov 24, 2008 | 08:33 PM
PAUL S's Avatar
PAUL S
I seem to remember tank baffle issues as well on these cars when the fuel level was at a certain height starving the pump of fuel when cornered, why not try it with different fuel levels
Old Nov 24, 2008 | 08:49 PM
silky16v's Avatar
silky16v
Get on That!
damp in the MAP sensor under the header tank
Old Nov 24, 2008 | 08:50 PM
martinembleton's Avatar
martinembleton
i have this problem but it happens on mine with right and left bends like it is straved of fuel even if u have half a tank!!!
it fu#ks me off
Old Nov 24, 2008 | 09:14 PM
m4ttyrs's Avatar
m4ttyrs
There is half a tank of fuel in the car at the moment. Mite try fiiling it to the brim. I'll have a look at the MAP sensor tommorow. Martinembleton does yours stop doing it if you fill the tank?
Old Nov 24, 2008 | 09:22 PM
cosmatt's Avatar
cosmatt
I had this on my saph,take the loom connectors apart and dry them out. Its the big ones that are on bulkhead on 4wd saph(not sure where on escos)m or even better hardwire them by cuttin plugs off.
Old Nov 24, 2008 | 09:26 PM
NUTS RuS's Avatar
NUTS RuS
Engine earth is my guess.
Old Nov 24, 2008 | 11:46 PM
costina's Avatar
costina
Live long and prosper!!
I'd say map too cos if they get wet there fooked,i chipped car and it ran fine,then i changed the cam belt so removed rad and drained water from header tank.
done the job and the car never ran rightchanged back to std and it was fine blamed the chip supplier and later found it was a faulty map which had water inside it
also blow the pipe out
Paul
Old Nov 25, 2008 | 08:39 PM
m4ttyrs's Avatar
m4ttyrs
I took the MAP sensor off, ran the car and moved the MAP sensor around does this mean its ok? surely if it did it driving round a left hand bend its going to do it if i tilt it side to side when the engine running.
Chas
Sep 21, 2015 08:57 PM
The Underdog
29
Sep 7, 2015 09:49 PM
Red_bull
Aug 9, 2015 08:34 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
