MOT Question
Old Nov 17, 2008 | 05:25 PM
Spiky's Avatar
Spiky
Default MOT Question
car has mot till end of nov,
took it for a test and failed
the car cannot be used now can it?
am i right?
Old Nov 17, 2008 | 05:26 PM
KSA-Cossie's Avatar
KSA-Cossie
Correct.
Old Nov 17, 2008 | 05:27 PM
Spiky's Avatar
Spiky
cheers
Old Nov 17, 2008 | 05:35 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
in the days before computerisation, if you got stopped you could just show your in date ticket, and nobody knew any different....
but now its logged on computer everyone knows its failed, and if seen on the road you could get pulled
Old Nov 17, 2008 | 05:40 PM
coco16i's Avatar
coco16i
Your current MOT is still valid up until the expiry date shown on the certificate, you paid for a 12 month mot and thats what you have, this very topic was brought up on here a while back and at that time we had a visit from VOSA at my work and i asked the dude about this and was told the certifiacte is valid up until the expiry date regardless of whether or not it has been presented for another test early and failed.
Old Nov 17, 2008 | 05:44 PM
JTECH James
Passion for Fords!
hmmmm, im not so sure, i will double check with my legal boffins at work tomorrow. i work for vosa btw
but driving a unroadworthy vehicle is an offence , nomatter when its tested and it invalidates insurance.
Old Nov 17, 2008 | 05:46 PM
coco16i's Avatar
coco16i
This guy i asked is one of them fuckers that knows everything about everrything when it comes to mot's, or so he would have you believe anyway !!! Interested to know whether he's right or wrong on this one though !!
Old Nov 17, 2008 | 05:51 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Agreed.
Old Nov 17, 2008 | 05:53 PM
focusv8's Avatar
focusv8
The legal position would be;
You CAN produce a valid M.O.T cert if required,
As it would appear a fail does not cancel the existing Pass cert, at the moment.
However you cannot produce a vehicle that will pass an M.O.T .
If stopped by Plod or Vosa you would fail an inspection and would be guilty of an offence under Construction and Use.
JTECH James
Passion for Fords!
but driving an unroadworty vehicle is an offence chaps....
it failing an mot renders it unroadworthy.
if you crashed, potentially your uninsured
Old Nov 17, 2008 | 05:56 PM
C4llyT's Avatar
C4llyT
No mot doesn't invalidate insurance, so if it's roadworthy it's roadworthy.
My insurance company don't require car to be mot'd, and neither has any other I've been with.
Old Nov 17, 2008 | 05:59 PM
JTECH James
Passion for Fords!
read the small print... every policy ive ever seen, even my trade policy states driving with known defects, or a vehicle in unroadworthy condition is not covered.
insurance companies love to not to pay up.
greenlight wouldnt cover the cossie untill it had current mot....
its the same as over tinted windows....they invalidate insurance , as it becomes unroadworthy. i dealt with a case of this not long ago
Old Nov 18, 2008 | 07:00 AM
Spiky's Avatar
Spiky
well i took the mrs car today, as i'm not chancing it.
the mot tester didn't even know the answer..
better to be safe than sorry
Old Nov 18, 2008 | 07:28 AM
It's quite possible to fail and MOT and still be roadworthy, they are two different tests.
I had this very problem years ago, and was told by Jean Paul, of Norwich MOT inspectorate, when he later examined my car, as I reported it, that the existing mot cert can still be driven on perfectly legally, I thne asked is my car dangerous to the extent that the plod can do anything, he said "no, it's safe to use, but won't pass an mot".
The problem on my car is it should not have passed on many things including corrosion, so was retested locally and he called the selling garage to view the car, actually gave him an option, to come over(he said he was busy) or lose his license, turns out that is what happened anyway.
I too was intrigued by the position of legally being able to drive on a cert of a test that it should not have passed.
Old Nov 18, 2008 | 07:58 AM
Spiky's Avatar
Spiky
well mine was a broken coil spring and handbrake.
but i chose not to risk it
Old Nov 18, 2008 | 08:04 AM
dojj's Avatar
dojj
Resident Wrestling Legend
fail on both
Old Nov 18, 2008 | 08:05 AM
Spiky's Avatar
Spiky
Originally Posted by dojj
fail on both
WOW thats amazing
of course it's a fail, i just told you
Old Nov 18, 2008 | 08:07 AM
999's Avatar
999
i only noticed today that the wifes car ran out of mot end of july... oops
Old Nov 18, 2008 | 08:12 AM
I think you would be in trouble with plod for that one, mine was just rust in chassis, plus a few other silly bits that soon fixed.
Old Nov 18, 2008 | 08:14 AM
notroubleclubber's Avatar
notroubleclubber
Back In The RS Game!
Done the same for my car. Asked the mot place if it was ok to drive as still had 2 weeks left on the ticket when it failed and they said yeah no probs but obviously no driving it after the 2 wks until a new mot is passed.
Old Nov 18, 2008 | 08:40 AM
dojj's Avatar
dojj
WOW thats amazing
just realised that
Old Nov 18, 2008 | 09:41 AM
St3V3_C's Avatar
St3V3_C
You can drive it. Thats the whole point of taking it in early - so you can run around legally getting it fixed before the old ticket runs out.
The only exception is if the tester states the car should not be driven on the paperwork.
Old Nov 18, 2008 | 09:45 AM
St3V3_C's Avatar
St3V3_C
Dude,
Punch your details in to this out of interest...
http://www.ukmot.com/check%20MOT%20online.asp
Old Nov 18, 2008 | 09:51 AM
St3V3_C's Avatar
St3V3_C
Your MOT is valid until its expiry date even if in the meantime your
car fails the MOT - the original pass is still valid. In fact you can have the Test done up to a calendar month before the expiry date and have the new MOT forward-dated to the expiry date of the existing certificate. So if you have your car Tested during that month and it fails, this gives you time to have the repairs carried out and the car re-tested before the expiry of the original certificate and you are not disadvantaged as a result. - MOTT.
From a place
"MOT Test information for the motoring public, the Testing Station owner, Authorised Examiner, Nominated Tester, repair and service technician"
http://www.motester.co.uk/mot-qanda3.html
Old Nov 18, 2008 | 09:52 AM
Spiky's Avatar
Spiky
Originally Posted by St3V3_C
Dude,
Make of the vehicle:RENAULT
Model of the vehicle:CLIO
Test Result:Certificate Issue Refused (Fail)
Colour of the vehicle:SILVER
Date of test:17/11/2008
Expiry date:
Odometer Reading:57434 Miles
VTS undertaking the test:V101201
VTS telephone number:02920 20888998
Old Nov 18, 2008 | 09:53 AM
Spiky's Avatar
Spiky
he put "dangerous" next to the coil spring
Old Nov 18, 2008 | 09:54 AM
St3V3_C's Avatar
St3V3_C
Expiry date:
Interesting, but I guess that's right as it's the latest info they have...
Old Nov 18, 2008 | 10:04 AM
St3V3_C's Avatar
St3V3_C
That would probably cover it then - you should NOT use it.
When you did that check - did you use the number from the fail sheet? If so, try the one from your old cert.
Old Nov 18, 2008 | 10:06 AM
Spiky's Avatar
Spiky
yeah from the fail sheet
i will use the old cert, when i get home and see what it says
Old Nov 18, 2008 | 10:12 AM
Doug's Avatar
Doug
Spiky This is a very very fucking grey area mate
from an mot point of view its still legal to drive ! hence why you are able to get a 13 month ticket or offer the vehicle for test 30 days prior to expirery ! point being so you can repair and still use the said vehicle
NOW !!!!!!!!!!!!!!!!!!!!
From a police prerspective its illegal and your fucked end of so in heinzsight id not use till passed but there is a good chance that if you got pulled and had to go to court you could win as vosa have put you in that position by offering 13 month tickets or 30 day early tests.
Regards Doug .
Old Nov 18, 2008 | 05:05 PM
Passing an MOT has NOTHING to do with ROADWORTHINESS, which is what the plod are concerned about, as Spkiy has fixed the items he can drive legally, as it is then roadworthy, and would not fail the next mot when presented.
It is still law that London Hackney Carriages must carry a bale of hay and a sack of oats, but plod won't do you for it if you don't.
Some other odd things, it is illegal to break a egg at the sharp end, doing so will land you in the village stocks for 24 hours.
Old Dec 19, 2008 | 02:52 PM
jbsportstech's Avatar
jbsportstech
Its not fit under construction use but it has a current MOT. Bottom Line
Old Jan 2, 2009 | 09:35 AM
RSTurboSI's Avatar
RSTurboSI
can you drive a car with No m.o.t or tax but with insurance to a test center thats book to take an mot? as long as it passes?
Old Jan 3, 2009 | 01:45 PM
vaughant's Avatar
vaughant
I dont believe it has to pass to be honest mate,but there are so many loopholes that the law can use these days it`s unbelievable, alot of them justified, a lot of them not. You`ve got to laugh at if you get stopped with a baldy tyre,it`s happenned to me twice. First time, the copper was sound and could see that the tyre had worn on the inner edge only and allowed me to get it changed within 14 days, which i did the next day and all was well. Got pulled then a year later,same problem and no arguments, your being done. I pleaded with him to put my mint spare on, as he could see it was worn on inner edge, not interested, fined me on the spot. Now i was given no document to say that i had to change the tyre, whereas had he given me a 14 day slip like the other guy, it would have to have been done, or i would be in court etc. If you do it though, book it in and make sure that there are no baldys etc. on it, exhaust hanging off and so on, as your then clearly driving a non roadworthy vehicle.
Old Jan 3, 2009 | 06:01 PM
dojj's Avatar
dojj
Regards Doug .
as long as he's not bodging 57 varieties of baked bean tins he'll be ok
but yes, get it fixed as the spring will cause you problems, especially if it escapes wile you are driving down the road
Old Jan 3, 2009 | 06:36 PM
bigjim172000's Avatar
bigjim172000
Me Cossie Runs Atlast!!!!
Your allowed to drive to the MOT Test station for the test and back home again if it passes or fails. How else are you meant to get back? And i dont exactly see millions of low loaders anywhere I also believe your allowed to drive the car to a garage to have the repair work carried out and then back to the test station again.
Old Jan 3, 2009 | 06:57 PM
Spiky's Avatar
Spiky
welcome to last year
Old Jan 4, 2009 | 08:30 AM
Paul.V's Avatar
Paul.V
Thumbs up
See what you've started now....lol
Old Jan 4, 2009 | 09:36 AM
Spiky's Avatar
Spiky
yeah, the car has been mot'd 6 weeks now
Old Jan 4, 2009 | 10:22 AM
Paul.V's Avatar
Paul.V
Totally off the subject how did Donny go?
