Fuel pump for zetec turbo
Old Nov 3, 2008 | 09:51 PM
woolford's Avatar
woolford
Default Fuel pump for zetec turbo
wanting to run between 280-300 what fuel pump and where can i get one from??
Thanks
Old Nov 4, 2008 | 02:27 PM
AlexRS2782's Avatar
AlexRS2782
At that power i would say standard pump will still be ok tbh - standard pump on mine (like injectors) was fine up to 330bhp
The direct replacement is the green top fuel pump which i believe is from the American Focus SVT - Pumaspeed sell them over here with a mark up or you can import direct from Central Florida Motorsport (CFM)
Old Nov 4, 2008 | 04:36 PM
pani_k's Avatar
pani_k
PassionFORD Member
I have a intank Bosch 003 Group A fuel pump that's good for a safe 350bhp if that is any good to you.
Old Nov 4, 2008 | 04:37 PM
pani_k's Avatar
pani_k
PassionFORD Member
Old Nov 4, 2008 | 05:11 PM
woolford's Avatar
woolford
Where and how much was this???
Thanks
Old Nov 4, 2008 | 05:12 PM
woolford's Avatar
woolford
By this i take you mean the standard pump from a focus rs???
Paul
Old Nov 4, 2008 | 07:10 PM
AlexRS2782's Avatar
AlexRS2782
Paul
Yep standard FRS pump
Old Nov 4, 2008 | 07:12 PM
woolford's Avatar
woolford
mint big thanks..
These are in tank are they hard to fit???
Old Nov 4, 2008 | 07:27 PM
pani_k's Avatar
pani_k
PassionFORD Member
You still want it mate, or do you have an FRS pump currently? If so, as above, standard FRS pump is fine.
Old Nov 4, 2008 | 08:44 PM
woolford's Avatar
woolford
how much?? pm me also are the in tank pumps hard to fit??
Old Nov 4, 2008 | 08:57 PM
AlexRS2782's Avatar
AlexRS2782
Guess its based on experience, etc, but when i had my pump changed the tuner had old one out & new one fitted in around 30 to 45mins
Old Nov 4, 2008 | 09:55 PM
tarmac terriost's Avatar
tarmac terriost
alex i have m8 who is building a zetec turbo 4x4 mondy and is planning to run 320bhp which fuel pump should he use as he as a split tank?he was planning on running rs focus injectors too would this be ok,would a rs focus fuel pimp fit or nto ?
Old Nov 8, 2008 | 05:22 PM
tarmac terriost
was reading on puma speed last night that this rs green and blue top fuel pumps will fit any ford in tank set up which was very intresting, also give calacutions of the flow rate etc too
Old Nov 8, 2008 | 07:15 PM
RSturboJET's Avatar
RSturboJET
Can't Find 'em? Grind 'em
You could use a small turbo escos pump which is an 044 or an uprated one which is an 048.
robnock
21
May 13, 2019 05:29 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
